Old October 12th, 2020, 16:21
techno1154's Avatar
techno1154 techno1154 is offline
One wheel bounce
Driver side front wheel,...I am out of options.
New Bilstein 5160's
New unit bearings,
New Chevy TRE,
New ball joints,
Check and re-check all fastener torque.
All new tires balanced and re-balanced.
Just that one side have a continuous bouncing when driving on some of these newish concrete road that is not very smooth at high way speed. It does display a mild case of death wobble at times.
For brakes the XJ is fitted with a set of WK (third generation Grand Cherokee 2006 model) rotors and calipers. The calipers are a bit warped. I have a replacement set but need to drill a second set of bolt holes at 4.5 inch instead of the 5 inch spacing.
Funny thing, I could drive up to 80 MPH on otherwise smooth highway with no indications of a shake or wobble. I am out of things to look at except a professional alignment.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old October 12th, 2020, 16:28
Vince's Avatar
Vince Vince is offline
Re: One wheel bounce
For a process of elimination you could try swapping the Bilsteins over from left to right and vice-versa.
Old October 12th, 2020, 16:49
techno1154's Avatar
I had the same problem with a different set of shocks. I also swapped the wheels front to back on that side.
The other item of concern is the 2" spacers/adaptors on all four wheels that allow the use of the JK OEM 17" wheels. I should start swapping them around also.
Patrick
#594
Old October 12th, 2020, 17:59
WAZZUXJ's Avatar
WAZZUXJ WAZZUXJ is offline
SoCal_XJ FB
Is the axle centered? Trackbar geometry and length correct? Trackbar mounts solid? Alignment done?
Old October 12th, 2020, 18:09
RCP Phx RCP Phx is offline
What tires? Sometimes they have to be "trued" before you balance them.
Old October 12th, 2020, 22:33
8Mud's Avatar
8Mud 8Mud is online now
Something that has been lost over the years, the good tire guys will check for round before they ballance.
Look at your front axle U-Joints, grease or even rust dust around the rubber seal for the bearing caps. Jack the tire/axle up and jam the U-joint yoke with a long ratchet drive extension or something similiar. Look closely with a flashlight where the X goes into the bearing caps.
I had one that showed none of the normal signs of U-joint failure but it would pick up a serious vibration or bouncing sensation at around 50 MPH and then it would disappear or minimize at higher speeds or lower speeds.
Old October 14th, 2020, 09:56
techno1154's Avatar
Thanks all for their reply.
I walked backward in my mind of the things I did recently that would affect drivability. Toe adjustment was the last one a couple of weeks ago. It was toed out and sowed signs of it with tire wear on the inside. When I pulled the toe in a little there was a noticeable improvement in eliminating wandering on slanted roads. Two days I returned the toe to where it was. Now the bouncing seem to be gone and the beginnings of Death Wobble. However, the following the down slope in the road have returned which necessitate a constant but light correction to the left.
It seem I have no choice but to take it to a pro to get it aligned. Enough of that drive way, eyeball, trades man level thing.
Patrick
#594
Old October 14th, 2020, 10:05
Are you scribing your tires so you get a good measurement?
Old October 14th, 2020, 20:12
lawsoncl lawsoncl is offline
and the lazy ones don't check the runout to see if you have a bent rim or bad tire.
Old October 14th, 2020, 10:37
WAZZUXJ's Avatar
SoCal_XJ FB
I tried multiple times to do an alignment with the tape measure, but could never get it dialed in just right.
I then used the string method, but instead of a string I used a construction laser level. It was so easy and the Jeep now tracks perfect.
Old October 14th, 2020, 16:00
techno1154's Avatar
How do you do that? What does the light shoot at?
Patrick
#594
Old October 15th, 2020, 10:13
WAZZUXJ's Avatar
SoCal_XJ FB
Set up the laser at the rear of the vehicle at mid tire height, about 12"-18" behind the rear tire.
Ensure the laser is level.
Set the laser so the distance away from the rear tire is the exactly the same when measured at the 9 and 3 O'clock positions. ( I set it at 1" away using a solid steel ruler)
Then starting with the passenger side front tire, measure the laser distance away again at the 9 and 3 O'clock positions. (You should be looking for about 1/16" to 1/8" toe in on the front measurement. Adjust the steering wheel to get the desired measurement)
Then move the laser to the driver side and set up the same way.
Measure the front tire the same as the passenger side. Adjust the tie rod to get the desired measurement.
Once the tie rod is set, then adjust the drag link to center the steering wheel.
Done.
Old October 16th, 2020, 10:50
Scrubber3 Scrubber3 is offline
One wheel bounce
What's your caster look like?
Sent from my SM-N986U using Tapatalk
Old October 16th, 2020, 18:47
techno1154's Avatar
Done.
Thanks. Good to know. I do not have a laser so I will not be doing it at this time.
It is about 5.5*.
Patrick
#594
Old October 17th, 2020, 15:50
WAZZUXJ's Avatar
SoCal_XJ FB
$30 at home depot.
'98 XJ front end bounce 97fordrunner OEM Tech Discussion 7 September 17th, 2012 12:22
Death "bounce" on stock XJ 3XJFamily OEM Tech Discussion 9 May 23rd, 2006 20:01
Wheel bearings or drum brakes? 8.25 sqeaky wheel.. ZachMan OEM Tech Discussion 3 February 24th, 2006 07:57
Base jumping bounce Roxtar Non-Tech / Off Topic 1 February 4th, 2005 08:35
