Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Commander XK (2006 - 2010)
Jeep Commander XK (2006 - 2010) Technical forum for the full-size Jeep Commander.
Old November 13th, 2019, 10:50
WB9YZU WB9YZU is offline
Recommendations for a Lift Kit
I am toying with the idea of lifting the Commander, and putting steel FR and Rear Bumpers on it.
The trails I'm thinking of are not 10s or Black Diamond, but your basic Colorado trail like Jenny Creek or Pickle Gulch.
There are spacer kits in the 2" range.
Then there is a Super Lift kit in the 4" range, but involves cutting the cross member and you can't use the OEM wheels.
What have you guys used, and what pitfalls did you encounter in the installation or actual use of the kit?
TIA
Old December 9th, 2019, 21:41
Re: Recommendations for a Lift Kit
Test
Old December 9th, 2019, 21:46
Sorry, I had an issue posting
I found lift kits, a number of puck ones, and one made by superlift.
Instead of going huge, I think I'm going to go "old school XJ" and do a 2.25" Spacer lift by rocky-road outfitters.
The bumpers are eluding me. I see WAM makes them, but nothing in stock.
I suppose I could create my own, but I've gotten lazy in my old age.
A lot of links for Commander Off-Road parts are going dead, I guess I'm late for the party
Old December 10th, 2019, 09:06
Skwerly Skwerly is offline
What year/generation are we talking?
Old December 11th, 2019, 16:50
Name of Sub-Forum I posted in: Jeep Commander (XK 2006-2010).
Unless I am mistaken, I don't think they changed a whole lot in 4 years
I'm looking at the OME kit, and the Rocky Road spacer kit. Huge price difference for springs/shocks/struts vs spacers
Update: No longer need the info:
Last edited by WB9YZU; February 19th, 2020 at 15:17. Reason: No longer need the info - Thanks
Old May 20th, 2021, 07:51
tonytech tonytech is offline
What brand of lift kit did you end up purchasing?
Old June 14th, 2021, 15:16
I never did get an answer.
After doing the research, I found that the lift was going to be 2" or go huge and do a bunch of relocation. The limiting factor seems to have been the front CV joints. I had trouble finding armor that I didn't need to make, so I scrapped the idea.
Eventually, I sold the truck, bought a JK Unlimited, and didn't look back (too far).
Old August 10th, 2021, 07:26
Oh, I see. Hope you are enjoying your JK.
Old August 17th, 2021, 22:06
Calvin Bnvds Calvin Bnvds is offline
Have you done any upgrade on your JK?
Old August 18th, 2021, 10:47
2DOORDAN 2DOORDAN is offline
thinking of adding new rear leaf packs in between the OME/ARB leaf packs part #'s as follow bso-33rb and cso-33ra I'm wanting to get no more than 3.5 to 4 inches any recommendations would be welcomed if anyone has experience with these leaf packs
thanks in advance
94 xj 2 door 4.0 forest service rig
4 whole injectors
1.75 spacers in front stock coils
rear add a leaf with stock shackles
dana 35 factory lsd with upgraded axles
3" lift recommendations jscusmcvet Modified Tech Discussion 8 November 6th, 2011 09:44
shocks recommendations for RE 3.5" lift R-IK Modified Tech Discussion 14 October 18th, 2006 22:00
Pls give me your $.02 on lift recommendations... CoastieJ Modified Tech Discussion 5 April 27th, 2006 01:57
Recommendations on a good 4.5' Xj lift kit HELP PLEASE 435Mj Modified Tech Discussion 35 March 31st, 2006 17:03
Need Lift/Tire Size Recommendations bdl220 Modified Tech Discussion 10 March 26th, 2006 11:05
