Test with the engine idling. Disconnect the vehicle vacuum hose to the valve, connect a hand pump to the valve, and pull a vacuum (opening the valve.) The engine should stumble, if not stall out completely.
To disconnect - pull the vacuum line off of the valve and plug, or pull it off of the solenoid on the fenderwell and cap the port. This is one case where an emissions device actually creates more emissions than it's meant to solve - some time ago, my 1987 failed emissions because the EGR was gone. You couldn't tell with the sniffer - the "tech" checked it the same way I just told you to.
Two hundred bones later, my EGR worked - and all my emissions numbers were significantly up. How's that work again?
