RWKHausSupply
- yorba linda, Cali
Now shipping Revolution Gear sets and master kits. These are some of the highest quality aftermarket gears on the market.
Stocking
D30-373 Dana 30 10 Bolt, 3.73 Ratio - Jeep, Bronco, Scout
D30-410 Dana 30 10 Bolt, 4.10 Ratio - Jeep, Bronco, Scout
D30-410R Dana 30 Reverse 10 Bolt, 4.10 Ratio - Jeep, Bronco, Scout
D30-456 Dana 30 10 Bolt, 4.56 Ratio - Jeep, Bronco, Scout
D30-456R Dana 30 Reverse 10 Bolt, 4.56 Ratio - Jeep, Bronco, Scout
D30-488 Dana 30 10 Bolt, 4.88 Ratio, 39X8T - Jeep, Aerostar, Bronco, Scout
D30-488R Dana 30 Reverse 10 Bolt, 4.88 Ratio, 39X8T - Jeep, Aerostar, Bronco, Scout
D30JK-411 DANA 30 Reverse JK FRT 4.11 R&P
D30JK-456 DANA 30 Reverse JK FRT 4.56 R&P
D30JK-488 DANA 30 Reverse JK FRT 4.88 R&P
D30JK-513 DANA 30 Reverse JK FRT 5.13 R&P
D30S-355TJ Dana 30S Short Pinion 10 Bolt, 3.55 Ratio - Jeep, Bronco, Scout
D30S-373TJ Dana 30S Short Pinion 10 Bolt, 3.73 Ratio - Jeep, Bronco, Scout
D30S-410TJ Dana 30S Short Pinion 10 Bolt, 4.10 Ratio - Jeep, Bronco, Scout
D30S-456TJ Dana 30S Short Pinion 10 Bolt, 4.56 Ratio - Jeep, Bronco, Scout
D30S-488TJ Dana 30S Short Pinion 10 Bolt, 4.88 Ratio - Jeep, Bronco, Scout
D35-308 M35 3.07 R&P
D35-355 Dana 35 7.562" 3.55 Ratio, 8 Bolt, 39X11T
D35-373 Dana 35 7.562" 8 Bolt, 3.73 Ratio, 41X11T
D35-411 Dana/AMC 35 7.562" 8 Bolt, 4.11 Ratio - Jeep
D35-456 Dana/AMC 35 7.562" 8 Bolt, 4.56 Ratio - Jeep
D35-456R Dana 35 Reverse 7.562" 8 Bolt, 4.56 Ratio, 41X9T
D35-488 Dana/AMC 35 7.562" 8 Bolt, 4.88 Ratio - Jeep
D35-488R Dana 35 Reverse 7.562' 8 Bolt, 4.88 Ratio
D44-354 22856-5X, Dana 44 8.5" 3.54 Ratio, 10 Bolt - GM, Ford, International
D44-354R Dana 44 8.5" 3.54 Ratio, Reverse 10 Bolt, - Chrysler, Ford, GM, Scout, Jeep
D44-373 Dana 44 8.5" 3.73 Ratio, 10 Bolt - GM, Ford, International
D44-373R Dana 44 8.5" 3.73 Ratio, 10 Bolt, Reverse , - GM, Ford, International
D44-392 Dana 44 8.5" 3.92 Ratio, 10 Bolt
D44-409 Dana 44 8.5" 4.09 Ratio, 10 Bolt,
D44-409R Dana 44 8.5" 4.09 Ratio(11 X 45), 10 Bolts, Reverse- Bronco, F100, F150, F250, F350
D44-410T Dana 44 8.5" 4.10 Ratio, 10 Bolt, Thick 41x10T
D44-427 D44 4.27 R&P
D44-455 Dana 44, 10 Bolt, 4.55 Ratio
D44-455R Dana 44 Reverse 10 Bolt, 4.55 Ratio
D44-455T Dual D44 Thick 10 Bolt Dual size, 4.55 Ratio 50x11T
D44-488 Dana 44 10 Bolt, 4.89 Ratio - GM, Ford, International
D44-488R Dana 44 Reverse 10 Bolt, 4.88 Ratio - GM, Ford, International
D44-488T Dual DANA 44 Thick 10Bolt Dual ,488 Ratio
D44-513 Dana 44 10 Bolt, 5.13 Ratio, 41X8T - GM, Ford, International
D44-513R Dana 44 Reverse 10 Bolt, 5.13 Ratio - GM, Ford, International
D44-513T Dana 44 Thick 10 Bolt, 5.13 Ratio
D44-538 Dana 44 10 Bolt, 5.38 Ratio, 43X8T - GM, Ford, International
D44-538R Dana 44 Reverse 10 Bolt, 5.38 Ratio, 43X8T - GM, Ford, International
D44-589 Dana 44 10 Bolt, 5.89 Ratio, 53X9T - GM, Ford, International
D44HD-411 D44-HD 4.10 Thick R&P(uses_D60_yke)incl. VIPER
D44JK-411 RUB D44 4.11 Thick R&P, Rear Jeep JK
D44JK-456 RUB D44 4.56 Thick R&P, Rear Jeep JK
D44JK-488 RUB D44 4.88 Thick R&P, Rear Jeep JK
D44JK-513 RUB D44 5.13 Thick R&P, Rear Jeep JK
D44JK-538 RUB D44 5.38 Thick R&P, Rear Jeep JK
D44RS-411 RUB D44 4.11 Thick Reverse Short R&P, Front Jeep Rubicon JK
D44RS-456 RUB D44 4.56 Thick Reverse Short R&P, Front Jeep Rubicon JK
D44RS-488 RUB D44 4.88 Thick Reverse Short R&P, Front Jeep Rubicon JK
D44RS-513 RUB D44 5.13 Thick Reverse Short R&P, Front Jeep Rubicon JK
D44RS-538 RUB D44 5.38 Thick Reverse Short R&P, Front Jeep Rubicon JK
F8.8-355 E7TZ-4209-B Ford 8.8", 10 Bolt, 3.55 Ratio, 39X11T
F8.8-373 F3TZ-4209-A Ford 8.8", 10 Bolt, 3.73 Ratio, 41X11T
F8.8-410 E9TZ-4209-B Ford 8.8", 10 Bolt, 4.10 Ratio, 41x10T
F8.8-456 Ford 8.8" 10 Bolt, 4.56 Ratio, 41X9T
F8.8-456R Ford 8.8" Reverse 10 Bolt, 4.56 Ratio, 41X9T
F8.8-488 Ford 8.8" 10 Bolt, 4.88 Ratio, 39x8T
F8.8-488R Ford 8.8" Reverse 10 Bolt, 4.88 Ratio, 39X8T
F8.8-513 Ford 8.8" 10 Bolt, 5.13 Ratio
C8.25-373 DUAL Chrysler 8.25", 12 Bolt, 3.73 Ratio, Dual Bolts
C8.25-390 DUAL Chrysler 8.25", 12 Bolt, 3.90 Ratio, Dual Bolts
C8.25-411 Dual Chrysler 8.25. Dual Bolts, 4.44 Ratio
C8.25-456 Dual Chrysler 8.25, Dual Bolts 4.56 Ratio
C8.25-488 DUAL Chrysler 8.25, 12 Bolt, 4.88 Ratio, Dual Bolts
AND many more!
Master kits avail for the above also.
Complete Gears and master install packages starting at $399.
All items ship same day as payment (if on a weekday).
Robert
RWK Haus Supply
[email protected]
714-875-2414
Stocking
AND many more!
Robert
RWK Haus Supply
[email protected]
714-875-2414
