Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > South East Chapter
South East Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
  #16
Old October 5th, 2022, 18:36
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: Waking the bear-1988 Cherokee
Originally Posted by PacificEd View Post
Both sets are power. I've been debating on how to handle that since the plugs and wiring on the late model mirrors seem to be rather large. I may take the time to find the connectors to make them fit right. Thanks for the advice and tips.
Sure thing. I was going to add a bit more info, but I'm at work and the stupid firewall/internet security package keeps scrambling what I type when I hit preview so it's gonna have to wait until I can do it from home.
I had some handwritten notes from when I did my mirror upgrade, I'll see if I can find them.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old October 7th, 2022, 07:28
PacificEd's Avatar
PacificEd PacificEd is offline
I've been driving the XJ for 4 weeks now and being very diligent but it got me yesterday. My RA was acting up, I was getting sore and stiff and I didn't quite make it. It got my first belt loop in 5 years. Those who know, know the struggle.
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
Current SEC Chapter Treasurer 2021-2022
Old October 8th, 2022, 17:33
PacificEd's Avatar
Last night, on my way home I heard a roaring coming from the Jeep that wasn’t there earlier. My suspicion was correct…….a bad rear u-joint.
Like everything for me, it became a more difficult task than it should have been. I had some new joints in my stash so I installed a new one and the 8.8 flange. Everything went back together well and seems good. Yay!
Completed rear driveshaft.
Old October 8th, 2022, 19:01
NAXJA Member #920
Well, I wasn't able to track down my notes - I might have tossed them after finishing the job, since they weren't all that complex. Now that it's the weekend and I'm not behind that company firewall, I can elaborate a little on the wiring conversion:
The older-style mirrors use the same 3-pin plug as the dome lights (it's also used for some sensor in 2004-2005 Ford Super Duty trucks, but exactly what escapes me. Scavenging the connectors from XJ dome light harnesses or broken mirrors is probably easiest). They use a "2-axis" system - one motor for up/down, one for in/out. Direction is handled by which polarity the 12V and Ground are connected to the motor through the control switch; the two "ground" lines from the motors share one pin on the connector (usually the black wire).
On the newer model mirrors, Jeep went to a larger, six-pin connector that has two rows of three pins. Some later mirrors are heated - when looking into the connector with the locking "nub" on the top, the two wires for the heating element should be the right-most pin in each row. The mechanism inside the mirror is basically the same (an up/down motor and an in/out motor), the other four pins are for the motors (same two-axis system as the old mirrors, but the two "grounds" from the motors get separate pins now.
I'm not sure if all 97-01 power mirrors use the same colors on the wires, and I didn't have a schematic, so I simply applied 12V and ground to the pins in pairs until I figured out what pin combinations caused the mirror to move in each direction and wrote it all down.
Then, I pulled the door apart and removed the old mirror. I twisted the wires onto the "new" connector and experimented until the mirror movement matched the direction I pressed on the switch, then I replaced the temp twistings with heat-shrink crimp splices and started reassembly.
Once I had it together I found that (as noted in several writeups on the topic) that there may be interference between the newer mirrors and the window trim; rather than try to trim the trim, I elected to just torque things down and fill the gap with a bead of black permatex RTV to seal the mirror to the door. Seems to be working fine, and isn't noticeable unless you go in close specifically for it.
Finally, I sprayed some white lithium grease into the pivot points (you can spray in from the bottom through a little cover you can pull, and from the top by folding the mirror half-way in) and worked the mirrors back and forth a few times to loosen them up, as mine were a bit stiff from sitting a while.
Best of luck in your swap - all in all, it's probably an hour or two of work for both sides, if you're fairly efficient with getting the door panels on and off.
1984 Dodge Omni
Rate This Thread:
1988 XJ - I6 - AT - Waking up after a 4 year sleep in a field. TLowery04 OEM Tech Discussion 9 March 10th, 2014 13:44
1988 Cherokee wht97xj SoCal For Sale 7 January 28th, 2013 14:39
1988 Cherokee 2dr 88 Honcho NAC Classifieds 5 September 8th, 2009 15:11
1988 cherokee Cartoad OEM Tech Discussion 17 February 6th, 2009 21:59
