speedo not working
tealxj97
edmonton
Hey guys once again my 97 xj has some strange gremlins going on. Its a 97 xj with an ax15. Just finished with floor pans and found out i don't have a working speedo anymore.
I've crawled underneath and checked to see if i melted or cut any wires and every thing looks fine. i just put the front driveshaft in and transfer case linkage and when i shift it i don't have the 4x4 indicator light in my gauge cluster either. Does anyone know if there is a wire or ground i may of misses or cut hidden away somewhere? it almost seems to me that the harness running down my transmission tunnel is dead for some reason. Only Check engine light i have is for the speedometer not functioning. thank you guys in advance!
Everything "looks" fine, or you used your volts/ohms multi-meter to test the related wires ?
