There is an easier way. Just start it up and run it, which I am sure you already have. Then just rev the engine to about 4K rpm a few times, and if everything is good, you will get oil pressure. This is a somewhat risky method on an older engine, but it will work. Go ahead and flame away at my hacker methods if you want, but results are what count. :firedevil
Like I said, if you really don't want to pull everything apart, and you already ran the engine, I say go for it. I haven't had good results with just cranking the engine until it gets pressure. I also use this method whenever I install a reman 4.0l engine. Since they are assembled somtimes monthes in advance there ie very little oil left in the oil pump to get a good prime.
I guess the proper way to do it would be to tear it apart and fill the entire oil pump gear cavity with vasaline. Once you do that, make sure you fill the oil filter with oil before installing it. Then just start the engine and you should be good.
Bryan C. AKA hack flat-rate mechanic :firedevil
