[email protected]
I currently have a RE 3.5" lift with 31. I am would like to go up to 4.5 or even 5.5" lift so eventually i will need a long arm kit. I am thinking of building my own, using RE super flex joints. My first question is how many of you have built your own? I also read a post that the tie in for the lower long arm should mount to a location other then the crossmember. Incase you have to remove the crossmember the front wheels will still be solid and in place. I was thinking maybe to make an additional cross member right in front of the Stock crossmember to tie in the control arms but it looks like i would have to drop it too low for it to clear the front drive shaft when it drops down (under flex) Anyway can you guys post pics of yours so i can get an idea of how you did it, and also give me any advice and what to and not to do? Thanks
