Old May 26th, 2018, 14:24
TRCM's Avatar
TRCM TRCM is offline
Re: Projext "V8 XJ" Build
Originally Posted by PhotoJared View Post
Ordered and received Hyland offroad hood louvers
FYI.....before you go too far and cut anything to install them.......
If you follow the directions, 1/2 of them won't be functional due to being blocked by the hood bracing.
Old May 27th, 2018, 00:50
PhotoJared's Avatar
PhotoJared PhotoJared is offline
Thanks for the heads up. I like hood louvers regardless of their functionality.
Old May 27th, 2018, 00:52
PhotoJared's Avatar
Engine is out
Old June 22nd, 2018, 21:16
gotwot gotwot is offline
Updates!!!!!
Old June 22nd, 2018, 23:43
clydefrog's Avatar
clydefrog clydefrog is offline
Originally Posted by gotwot View Post
Updates!!!!!
Yes!
M
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old June 24th, 2018, 01:39
PhotoJared's Avatar
No real updates. Trying to find a groove and balance of working in the garage. I welded in the passenger frame stiffener...or what I thought it was. See the 3 holes? Yea thats supposed to be for the steering box. I didnt know the stiffeners were directional. I drilled a few holes in the driver side stiffener and we're in business. I'm working on welding that in now.
Old August 4th, 2018, 16:48
PhotoJared's Avatar
Ramping this thing back up. I need to pull off the driver frame stiffener because I forgot to clean the medal behind the weld. The welds are popping too much to get something clean.
I'm also thinking of ordering this:
http://iq3s.racepak.com/
Thoughts?
Old August 4th, 2018, 20:27
trippled trippled is offline
They ain't cheap, but the coolness and functionality factor is high! Seen those used on a lot of the higher end builds on pretty much anything.
Old August 5th, 2018, 13:54
CastorTroy CastorTroy is offline
Thoughts?
This is what I've been considering for my (down the road) 5.3 swap. My reasoning being that it's not a race car and doesn't need a $1000 dash.
Old August 5th, 2018, 17:16
PhotoJared's Avatar
Looks cool, but doesnt have OBD2 support (which is why I'm considering the Racepack)
Old August 5th, 2018, 17:22
They sell a version that uses a bluetooth obd2 adapter. Not perfect, and honestly I would assume the racepak is a better unit. But this is also 1/5 the price.
Old September 14th, 2018, 11:08
PhotoJared's Avatar
Ok Guys. We need to chat...
I just found out that i'll be relocating to Dallas, TX. I have 2 non-running Jeeps currently and I need to sell at least one of them. What do I do?
Here's what I'm thinking. I can get the red jeep running pretty quickly (just need to swap the intake manifold back (that way I can get it on and off a trailer). I'm also thinking of swapping axles and long arms from white to red. That way the red jeep is nearly complete with built axles. The axle swap should only take a weekend or so (just need to drill a few holes.
Thoughts?
Old September 14th, 2018, 11:12
XJwonders XJwonders is offline
Huh, what?
Just keep whichever one that require the least amount of work
Old September 14th, 2018, 12:18
PhotoJared's Avatar
White jeep is running and is 100% just need to get the engine back in. Not sure how much I could sell the red jeep for though. $13k into the engine swap + the Jeep. I'd get what? $5k?
Old September 14th, 2018, 12:57
sandfreestyle sandfreestyle is offline
No way of keeping both?
BUILD: My 1987 "Wagoneer" XJ Limited Crist Clapper OEM Tech Discussion 319 August 29th, 2019 17:52
Troy's "I need to quit working on my wife's Jeep" build troy5118 Midwest Chapter 64 November 28th, 2017 23:09
my "wannabe jeepspeed" grand cherokee build grandrunner JeepSpeed, Prerunner and Competition Tech Forum 157 July 1st, 2014 04:48
Project Jericho Stroker build. "The Craigslist Homerun" jwittlock Modified Tech Discussion 36 December 29th, 2012 03:14
98 XJ Sport, lifted "Project Impound Build" XJ&CHZ4ME MWC For Sale/Wanted Forum 5 May 20th, 2011 13:19
