xratedj
- chandler, az
$3000
152k
40k on new 4.0 H.O. long block
AW4
NP-242
ABS
Rusty's 3" w/Quick discos
BFG 31x10.50 AT w/chrome wheels
Dana 30 front
Dana 35 rear
3:55 ratio
Homebrew roof rack with full size spare on it
CC, pwr door locks, pwr, windows, pwr seats, pwr mirrors
AC just sopped working, checked fuses, relays. Was told might just be low on freon.
ALL NEW since new engine:
GDI 3-core radiator
water pump
Hoses and belt
Thermostat
fan clutch
red top battery
cruise control unit
fuel pressure regulator
O2 sensor
CPS
plugs, wires, cap, coil, and fuel filter
ABS compressor
master cylinder
computer
brakes and abs sensors
High flow cat and turbo muffler
All fluids have been changed over to Mobil one
Has new drivers side hub, (changed at 120,000) and I still have the old one. (which is still good) The problem was a suspension noise which was cured with the lift.
Just put a new head liner in 2 weeks ago.
I will post some pics later after i wash it........
152k
AW4
NP-242
ABS
Dana 30 front
Dana 35 rear
3:55 ratio
GDI 3-core radiator
water pump
Hoses and belt
Thermostat
fan clutch
red top battery
cruise control unit
O2 sensor
CPS
ABS compressor
master cylinder
computer
