Old September 11th, 2011, 11:13
VanDerKen's Avatar
VanDerKen VanDerKen is offline
Question about 4.10 rear axle options
Okay, here's what I have: an '87 Pioneer with a straight 6, automatic, 242 transfer case, dana 30 front, and dana 44 rear with a limited slip (both axles are running 3.55's).
What I'm looking for is some input on getting 4.10 gearing into the rear axle on a "corn-nut" budget. The front will likely be a swap in from the wrecking yard.
options are:
- bite the bullet and change the carrier on the 44 and do a re-gear?
- buy a set of thick gears for the 44 and continue to use the original carrier?
- swap in a Ford 8.8 with 4.10's in it (upside is disc brakes and a stock limited slip)?
- look for the rumored MJ dana 44 with stock 4.10's and swap that in?
- sell the Heep and buy a 4x4 Geo Metro?
Mind you that this is just a Q/A session and have nothing planned just yet. Heck, I don't even have the money to consider doing anything. So let your opinions and ideas flow.
Old September 11th, 2011, 13:21
cheapcherokee93 cheapcherokee93 is offline
<----boat-manche
Re: Question about 4.10 rear axle options
i'd go the 8.8 route. hard to fine one with 4.10s but in the end you have disc brakes also which is a nice bonus.
Old September 11th, 2011, 14:34
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Finding a used 8.25 would probably be the cheapest. You could do disc swap as well. Some say the D44 is better than the 8.25, but IMO they are pretty close.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old September 11th, 2011, 15:17
VanDerKen's Avatar
True about the 8.8, I pulled one for my brother to do a swap into his own Cherokee that was a 4.10 with a limited slip standard, but his out of pocket cost is a little more than what I was hoping to do (drive shaft flange yoke, spring kit, brake lines and parking brake, shocks...).
I had not considered an 8.25 as being a candidate for 4.10's (will have to do some extra research).
Old September 11th, 2011, 15:35
Piece of Fish!
Red face Re: Question about 4.10 rear axle options
As far as the C8.25 goes, any gear ratios our XJ's use, there is no carrier break. So you can use the stock carrier for any gear set you want. Some had LSD, but you can go with a lunchbox locker.
Old September 11th, 2011, 18:42
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
I guess that depends where you look. They seemed to be pretty plentiful in my neck of the woods when I was searching for them. I got mine from the Pull a Part for under $100 complete.
Take your time and search around the local wrecking yards. Bound to be some somewhere. Just remember with the 8.8 you need to plan to spend some cash getting it set up (spring brackets and shock mounts and such) unless you can cut and weld it yourself.
Dirk DeYoung--Member #176--National Vice President, SEC President
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2006 XK (TOW RIG)
Old September 12th, 2011, 04:19
VanDerKen's Avatar
The Ford Explorer door tags are so informative when it comes to the axle types, find the right axle code and likely you'll find what you're looking for.
I wasn't thinking much about a locker but if the situation presents itself I may.
Old September 12th, 2011, 09:43
ParadiseXJ's Avatar
ParadiseXJ ParadiseXJ is offline
Did I miss something?
You want to put 4.10's in the rear, and leave the 3.55's in front?
Old September 12th, 2011, 12:02
Cottontail's Avatar
Three-De Off-Road
I read his OP as he was going to get a 4.10 front from an equipped XJ and then upgrade the rear. That is how I did mine...found a 4.10 front from a 1986 and went from there...so maybe I just assumed he was following the same path.
Old September 12th, 2011, 13:44
RCP Phx RCP Phx is offline
Theres no way in hell I would give up a D44 for a C8.25 or a 8.8! The carriers are dirt cheap or just buy the thick gears.
Old September 12th, 2011, 17:34
VanDerKen's Avatar
Thanks for the back up Cottontail, that was pretty much the idea that I had too. There is the option of just running a 2x4 and use the front drive shaft as a rear hatch rod, but then what would be the fun in that?
RCP, thanks for the vote of confidence in the 44 plan. You are my hero for the moment (the wife is the hero for the evening since she just made dinner).
Old September 12th, 2011, 20:37
bcjeeper bcjeeper is offline
if you're not wheelsing it why not just pull the front axles and have a 2 wheel drive? that shuold save you some cash. or even easier just pull the front driveshaft
Old September 12th, 2011, 22:49
cliffv cliffv is offline
Take one of those 44's hiding behind your garage, throw in some 4:10's and a detroit and call it done. Once I get a free weekend, I'll shop around for a front end for you.
xoxo
Cliff
Old September 13th, 2011, 19:30
VanDerKen's Avatar
Cliff
What? I don't know what you are talking about. Those alleged axles you may be refering to are intended as stocking stuffers for Christmas. As I can tell you may have hit Santa's s*** list
You may be getting a lump of something and it may not be a lump of hydrocarbons.
rear axle question XJ4Christ SoCal Chapter 10 October 26th, 2010 12:38
XJ 1999 5spd 4.5inch RE -- NP231/rear drive shaft/gear options/shim options please cooljeepnorthxj Modified Tech Discussion 11 February 4th, 2009 20:41
97-01 8.25 rear axle question chopperz OEM Tech Discussion 2 January 18th, 2008 18:57
Rear axle options XJ92jeep Modified Tech Discussion 9 March 21st, 2004 09:37
Options for rear axle shafts BrianG Modified Tech Discussion 7 July 3rd, 2003 08:58
