Johnny joints
Wikkid98xj
NJ
Does anyone know the pn. For the johnny joint upgrade for the d30 axle mount bushings
Sent from my SM-G986U using Tapatalk
Careful you don’t tear off the passenger side upper control arm mount from the axle if you use all hard joints.
That is a very good point.
And probably the reason there is a kit for these that includes a solid steel insert for the passenger side, intended to be welded to the axle tube.
