solomon7
- Portland OR
Every couple years a gremlin in my 96 XJ gets pissed and gives me a misfire code on #3 and #4. Code 43 43 when I do the key trick.
I normally disconnect battery terminals, and touch cables together for 30 seconds and it resets the CEL for a few more years.
My positive connector is FUBAR and a PITA to get off.
Would disconnecting just the negative terminal for an hour do the same as touching the cables together? WOuld it reset things the same?
REALLY don't want to pry the + terminal off again if I don't have to. Yes, I'm getting new cables in summer.
Would just disconnecting the - terminal work??
