Old June 24th, 2006, 10:32
rockreadyyj rockreadyyj is offline
temp gauge acting crazy
99 xj 4.0 we went wheeling last weekend and a couple hours through the trail the check engine light came on and then the temp gauge started going from 210 all the way the the red then back to 210 then to 100 back and fourth pauseing randomly. the jeep was running fine, not hot at all. i tried changing the sensor and it didn't change anything anyone ran into this. any ideas. its still doing it
thanks
mike
Old June 24th, 2006, 10:35
canadianwheeler canadianwheeler is offline
Re: temp gauge acting crazy
Try changing your thermastat. Also check your water pump. When my water pump went it wasnt leaking but my temp gauge was jumping around everywhere.
Old June 24th, 2006, 13:59
its not actually running hot the guage ismoving too fast for that its got to be electrical. i am thinking its the computer any ideas
Old June 24th, 2006, 14:12
5-90's Avatar
5-90 5-90 is offline
Simplest explanation first - replace the sensor. Since OBD-II uses a single sensor for pretty much everything temperature-related, start there.
Thermistors are usually pretty solid, but they can go to Hell REALLY fast once they get started...
5-90
Old June 25th, 2006, 13:28
already tried changing the sensor
Old June 25th, 2006, 13:33
Rambo's Avatar
Rambo Rambo is offline
it happend to me too, i unplugged the o2 plug(wire part) and found it was full of water, so i cleaned it an added some dielectric grease and never did it again!
Old June 25th, 2006, 21:22
ROADLESS's Avatar
ROADLESS ROADLESS is offline
Question Re: temp gauge acting crazy
Here's another good one. My son's 88XJ temp gauge pegs all the way out, but only when he turns on his headlights! Then as you dim the interior/instrument lights it goes back down like a rheostat switch! Bet no one has heard of this and if so, enlighten me!
Old October 4th, 2008, 22:51
90XJLtd's Avatar
90XJLtd 90XJLtd is offline
I know this thread is really old but this is exactly what I'm looking for right now. I'm trying to help a buddy fix up his 88 and it is a mess in every way. What the heck do the lights have to do with the temp gauge! Somebody help please!
Old October 5th, 2008, 12:53
juniorXJ juniorXJ is offline
electrical. thats how. grounds grounds grounds. at least start there.
Old October 5th, 2008, 12:57
90XJLtd's Avatar
I started my own thread on the lights making it skyrocket to focus on that subject itself. I will check the grounds. Thanks. Here it is.
http://naxja.org/forum/showthread.ph...#post244070678
Old October 5th, 2008, 15:50
birchlakeXJ's Avatar
birchlakeXJ birchlakeXJ is offline
If you changed out the temp sensor already, then the problem would most likely be in the wiring/connector for that circuit OR possibly (not probably) the gauge itself. Good Luck!
oil pressure gauge going crazy Darky OEM Tech Discussion 1 June 8th, 2005 11:32
'94 XJ Did the gauge swap, temp gauge doesn't move while driving caspergotaz28 OEM Tech Discussion 1 April 24th, 2005 15:08
Temp gauge way off? brtb OEM Tech Discussion 13 July 14th, 2004 08:00
Temp Gauge 2wdxj OEM Tech Discussion 3 June 14th, 2004 20:39
Temp Gauge acting screwy RedJeepXJ OEM Tech Discussion 7 October 2nd, 2003 17:28
