hey guy i did the old key trick check engine light flasher. I came up with these codes and used a legend. Anyone tell me wut the cause could be for eachone. i am stumped!!!!
12
Battery Disconnect Direct Battery Input to Powertrain Control Module (PCM) disconnected in last 50 key-ON cycles
24
TPS Voltage too High/Low Throttle Position Sensor (TPS) input voltage outside acceptable range
23
Air Charge Temperature Sensor Voltage too High/Low Manifold Air Temperature (MAT) sensor input voltage outside acceptable range
51
HEGO Sensor Signal Stays "below centre" HEGO Sensor indicates constant "Lean AFR" condition
55. the End
Heres where i got the codes.
http://www.geocities.com/JeepI6Power/obd1.html
12
24
23
51
55. the End
