hawk_sixsix
- L.I. New York
97 XJ 4WD
Did the V8 ZJ steering, finished my garage alignment, torqued it down, and then noticed the aluminum steering gear spacer was cracked. If the original box was coming out, a new one was going in.
Keeping in mind that the steering was just aligned . . .
Is it best to swap the pitman arm to the new box now, before installing? (Can the gear be turned lock-to-lock, splines counted, exact center found, etc.)
OR should the pitman arm be installed last, with the steering and wheels straight and steering shaft already connected?
