Mr.G & Family
- Victorville, Ca
30 front 8.25 rear 29 spline with np231
the axle housing is the same diameter anyway if its a 27 or 29 spline.How do you know its a 29 spline?
most likely:thumbup:Because that's the stock spline count, and since he hasn't upgraded (we assume), it's probably 29 .
the new model xjs came with the 29 splines older came with 27.I see. I have no idea what year my 8.25 came out of and the little id tag is missing so I dont know if its 27 or 29.
:thumbup: there's the correct info.It's a 27 spline seeing as how your jeep in not 97 or newer. It can easily be updated to the 29 spline version.
Much better than D35 but not quite as good as D44...from what I have heard
Pull the cover and count the splines. My early '96 has a 27, the one going in the '89 is 29.I see. I have no idea what year my 8.25 came out of and the little id tag is missing so I don't know if its 27 or 29.
