Citat3962
- Denver Colorado
I get this squeaking sound from the front axle... but only in turns.. its quiet when going straight..
And it's dependant on the speed.. like it's a single squeak per axle rotation and as you speed up the frequency of squeaks increases.
I'm thinking it's gotta be something rotating.. wheel bearing, loose u joint or u joint in need of grease..... or... God forbid something ALREADY going wrong inside the diff of the Turdy...
I'm thinking that because it makes noises only when turning it's gotta be the wheel bearing or whatever joint is used at the knuckle...
It's not THAT loud.... just a little bit noisy in the turns...
My Heep is a
91 4.0L I6 with an Ax4 transmission 231 T case and the usual D30 front D35 rear axle combo.
I just got this Jeep so any info would be a big help!
EDIT::: In fact since I know it's a vacume Disco axle the internals arent spinning in 2WD right?? Just the Hubs and bearings in the knuckle right?
That would pretty much make it an issue with the knuckle bearings/wheel bearings... or the joint at the knuckle.... hopefully it's just a joint in need of grease.. thats the cheapest..
My Heep is a
