Uglygreenxj
- Circle City, AZ
I replaced the rotors, calipers, & pads on my 93' XJ today. The installation went beautifully. My son and I have bled the system about seven times now and can't seem to get all the air out and the pedal wont come up.
Starting at the furthest wheel (from the master cylinder), I put a small rubber hose on the bleeder and the other end in a jar of brake fluid. I then open the bleeder and have my son slowly depress the brake pedal and hold it down. When the air/ fluid stops coming out I close the bleeder. We repeat this till I only get fluid. Every time I go back to the furthest one, it has just as much air in it as the first time.
It takes about three to four pumps of the pedal to get the Jeep to stop decently. Once when I returned from a test ride down the block, upon opening the hood I found fluid all over the underside of the hood above the master cylinder and all over the booster. I cleaned it all off and had my son pump the pedal but could find no leaks. Can't seem to find any other leaks either.
Someone please help! I'm about ready to light her up and let the kids roast marshmallows!
Thanks,
Dave
Thanks,
Dave
