Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > South East Chapter
South East Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Old October 14th, 2014, 13:00
Georgia Mike's Avatar
Georgia Mike Georgia Mike is offline
Frame rail stiffening options & opinions
Looking to do a bit of frame rail strengthening on my beater. I've looked at a few suppliers and was just wondering who you used? One of the areas I'm concerned with is over, and just in front of the driver's rear tire. The PO did a number on it and the rail is a bit crunched there from a rearward impact with a tree. It's not too bad, but while I'm doing the work I'd like to address that area for sure.
I'm also contemplating making a set of main rail stiffeners out of 3x3 angle. The only drawback is my local steel supplier says the thinnest they can get is 3/16", which seems a bit excessive and on the heavy side to me. The positive side to going that route is that it's only $55 for a 20' stick.
Let's see some pics of yours, tell me how you like/dislike them, how you made them, or what you'd do differently if you could do it again.
Old October 14th, 2014, 13:01
shortxjdoug's Avatar
shortxjdoug shortxjdoug is offline
Buy the hdoffroad set. The time you save in fabrication is worth the $$ for buying premade stiffeners
Old October 14th, 2014, 13:04
Cnickgo Cnickgo is offline
Do you need assistance?
Re: Frame rail stiffening options & opinions
You will quickly find we are all very partial to HDOffroad. You won't regret the purchase.
Old October 15th, 2014, 06:03
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
You should look at mine. 3x3 3/16. Up side is I mounted my long arm mounts to them and they are beefy. I land on them and drag them over rocks all the time.
I would and will agree 100% and go this route next time. As I get older the more I agree with what Doug says here.
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old October 15th, 2014, 09:13
256offroad 256offroad is offline
Ive got the HDOffroad on mine. front to rear and I added some more bracing here and there.
My old jeep had the TNT set and they were pretty good.
Old October 15th, 2014, 20:00
OK, I just ordered the HD Offroad full set!
Old October 16th, 2014, 05:22
Ghost's Avatar
Member Number 257
If you told Brian you liked to pick on me he'd probably give you a discount......
Old October 16th, 2014, 11:18
Hmmm, I told him I knew you and he charged me more
Old October 16th, 2014, 12:04
PacificEd's Avatar
PacificEd PacificEd is offline
That sounds more like it.
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
Old October 20th, 2014, 07:43
The Hard Struggler's Avatar
The Hard Struggler The Hard Struggler is offline
This statement made me laugh! All roads lead to Doug. I agree %100! Lol!
Old October 20th, 2014, 09:56
that just means the plan is working......
Old October 21st, 2014, 17:11
Stiffeners came in today! Too bad I'll be stuck doing other projects this weekend and won't get to install them
Old October 22nd, 2014, 07:10
Ghost's Avatar
Member Number 257
Did you get the full set? I'll be doing a transmission drain and filter replace on greenie. Might do a header on a stroked TJ too.
Old October 22nd, 2014, 10:40
Yeah, got the full set. What really blows is we have a CNC laser and a couple of huge press brakes here at work. All this stuff would've been super simple to make; you know, if I didn't have to worry about getting fired for doing "government jobs" and all that lol
Old October 22nd, 2014, 12:08
Luke95's Avatar
Luke95 Luke95 is offline
I'm going to be at 2/3 of a set soon. After I do the rears I am doing the fronts
Rate This Thread:
Frame Stiffening wheeling365 Modified Tech Discussion 7 July 9th, 2011 18:22
frame stiffening/plating Frédéric CM JeepSpeed, Prerunner and Competition Tech Forum 13 January 22nd, 2011 16:26
Frame stiffening process Part 2 of 3 finished! (PICS) TMR Frame Plates crazyjim SoCal Chapter 16 November 21st, 2008 10:46
frame stiffening az4wheeler2002 Modified Tech Discussion 1 November 19th, 2005 11:54
leaf spring inside frame rail...opinions? gearwhine Modified Tech Discussion 12 June 11th, 2003 20:49
