Old March 5th, 2018, 12:05
Faz95XJ Faz95XJ is offline
HF or Northern tire changers
Anyone have any experience with the Harbor Freight or Northern Tool manual tire changers?
Trying to remove tires to patch some holes and use for spares on the trail.
Was following the Bleeping Jeep UTube video, but had a close call with a flying pry bar and hoping for something a bit safer maybe.
Iím trying to remove and then reinstall 33x12.50 on 15Ē steel rims.
Old March 5th, 2018, 12:11
DutchVDub's Avatar
DutchVDub DutchVDub is offline
Re: HF or Northern tire changers
Pretty sure its not much different than using a good set of tire spoons other than you use that upright tube in the middle as a pivot to try and spin the bar around. I guess for 50$ its worth a shot, but Walmart will patch a tire for $10 or $15.
Americans can sleep at night because US Soldiers stand ready to fight
Old March 5th, 2018, 13:49
RCP Phx RCP Phx is offline
Oh it's a lot better than tire irons. I installed a HF unit when I moved into this house, that was almost 20 yrs ago and I do "alot" of tires! You need to bolt them down good!
Old March 6th, 2018, 08:30
My holes are on the sidewalls. Donít think they will touch them.
Old March 6th, 2018, 08:31
And it works on larger size tires- 33x12.50?
Old March 6th, 2018, 12:37
12.5's are no problem. I would say over the years we've done up to 14.5's!
Old March 7th, 2018, 10:27
akendal4's Avatar
akendal4 akendal4 is offline
Some practice with a half decent set of spoons and you can mount/dismount tires quickly. I swapped a set of 5 tires from one set of wheels to another in 30 minutes.
Old March 8th, 2018, 04:36
What spoons do you recommend?
Or, better yet, what are you doing this weekend 😃
Old March 8th, 2018, 06:41
akendal4's Avatar
I have 3 of these.
https://www.northerntool.com/shop/to...3914_200673914
Depending on where you are in VA, I'd say come on down
Old March 8th, 2018, 08:48
burntkat burntkat is offline
NAXJA Member #1145
Tyrepliers and spoons are all you need
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old March 8th, 2018, 18:05
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
Iíve broken 2 HF tire changers, they work ok on the first few 235 with weak sidewalls, once it came time to place the new 31 tires with stiffer sidewalls it was useless. Even after the first 235s the tool started to bend. Iíve used professional tire machines to break down rims before, in concept the manual tire changer can work, just not this cheaply made.
Northern Tool used to have a more substantial tire changer but they to have fallen to the dark side of cheap Chinese tools selling a rebadged HF tire changer.
HF tire changer may be ok for car tires.
Old March 14th, 2018, 07:57
I have 3 of these.
Iím in chesterfield. Where are you?
FS: Tomken Rear Bumper w/ Swing Arm & Tire Carrier for XJ - Northern VA kineticMJ NAC Classifieds 1 August 16th, 2011 05:31
need help- will pay- northern va kurazy kracka South East Chapter 1 May 23rd, 2010 07:41
need help- will pay- northern va kurazy kracka North Atlantic Chapter 1 May 22nd, 2010 23:06
cd changers.. cal SoCal Chapter 4 July 7th, 2005 09:10
