- Colorado
Yo jeep fam!
Well, as the title suggests I'm building some long arms.. I currently have mid arms but they need to be longer, so if I'm gonna invest the time and effort might as well go LA is my thought
SO, I'm starting with the dirt bound center section and will be running either 2x2 square ¼ or 2" x .25 dom for the lowers and 1.5x .125 dom for the upper. I'll be using the Johnny joints for lowers all around and body side upper.
I need to make the upper link to mate to the joint om the axle housing (driver) and likely Johnny joint body side, or maybe reuse the heim inhave currently.
As for bungs... is there a more desired threaded bung to use than others? Do I use round bugs even if I go with the square for the lowers?
Is there a general consensus on length per lift for lowers? Or just mock up with pvc and er on the long side (joints all the way screwed in)?
Any flaws in my logic so far? Thanks for any input
