8.8 from T-Bird
woody431
Virden, IL
Most of the later 80's Ford Thunderbirds came with 8.8 rear ends with disc brakes. My dad's does I know, but I was wondering if these would work ok on an XJ? I know that the springs are under the axle so I'd have to cut those off and weld perches on the top, but would the width be ok? I know of a few T-Birds that I could get one from, so I'm just curious. THanks
are you sure it is not a 7.5" i heard that is what's under most ford cars. i would check the tag if i were you, they look almost the same.
just a thought, correct me if i am wrong
I'm sure. Some may've had 7.5's but alot of the 87-88 Turbo's had 8.8.
Taken from Turbotbird.com
87-88 Turbo T-Birds
Gearing:
3:55 final drive ratio with T5 transmission,
Gear ratios: 1st - 3:97, 2nd - 2:34, 3rd - 1:46, 4th - 1:0, 5th -0:0.8
3:73 with the A4LD auto transmission
8.8" rear end
I used a 8.8 from a 89 lincoln mark VII, works great, is the right width, disc brakes, right bolt pattern too.
I believe the Lincoln's and the T-Birds are close to the same...Hmm I wonder if my dad would care if i borrowed the rear end outta his 88. lol
