NAXJA is having its 18th annual March Membership Drive!!! Everyone who joins or renews during March will be entered into a drawing! More Information -
Join/Renew
At what temperature should the electric fan come on with the a/c off
I’m sure there is a temperature switch for the eclectic fan were is it located and could I install a lower temp switch so the fan will come on earlier?
3. Would an exhaust leak cause the engine to run warm due to built up back pressure on the motor
I have a 1999 XJ, and I'm pretty sure I've seen the CTS sending unit coming out on the drivers side of the thermostat housing. The wire itself is covered with a plastic wire loom. This is a whole lot different than my '89 XJ, where it comes off the back of the engine block near the valve cover...
Replace the temp sending unit. Its on your thermostat stat housing pointing out of the upper driver side. I recently had the same problem. Went thru all my relays and they were fine. Temp Sending unit looked okay and wasn't but a couple years old, but I replaced it and the fan started working.
Not sure on the earlier year XJs, but on the 97+; the fan motor is constant hot and switched ground....
I installed a 12V relay that allows for normal use of the fan when the A/C is on, but can switch in additional ground for running the fan in bypass to cool the engine while off roading if the A/C is off....
