swapping the 8.25 for a d-35
jeepnuts311
Atlanta, Georgia
my moms 95 auto 2wd cherokee ate up its rearend and needs a rebuild or replacement, strength is not an issue on this jeep, it is 100% grocery getter.
i have a dana 35 out of a 1990 xj that i just swapped out for a dana 44.
i will be putting the spider gears back in and i wanted to swap it for the chryco, but the snout of the pinion on the dana 35 is about 3" shorter than the chryco, will i need a driveshaft from a 2wd with a dana 35, or will the stock d/s work?
i know its unusual to swap from stronger axle to weaker axle, but a free down-grade is better than dumping money into a stock axle for a rebuild.
i dont know whats wrong with the chryco, but it sounds like horrible backlash and also bad bearings.
thanks
-tim
Swap the 35 in and have the driveshaft lengthened. Making the driveshaft longer shouldnt cost more than $75 and you already have the dana 35. Beats $250 labor to have new bearings installed plus what ever the cost of parts will be.
AARON
