Old January 6th, 2007, 13:15
PosiDave PosiDave is offline
Voltage drop (Searched). Please help.
A little after thanksgiving I replaced my altenator and battery. The Altenator was bad but the battery was really old. I was making my 3 hour trip home this weekend and my Voltage dropped and it sits right above the red. The generator light came on. I didn't wanna have another break down so I drove the hour home and grabbed my other truck. I cleaned did a few things.
-Cleaned terminals
- Checked the altenator
- checked the ground on fender
- Checked tension of the belt
my oil pan has a leak by the starter and I cleaned those a little but didnt disconenct and reconnect.
The belt doesnt make any noises.
But the battery gauge is still right on the border of the red. Should I just switch the cable and go from there?
Its a 4.0 HO, Manual, with 232K. The Starter and selinoid were also replaced at 216k. The Battery Cables I do not know when they wer elast changed if ever.
Old January 6th, 2007, 14:07
shelbyluvv's Avatar
shelbyluvv shelbyluvv is offline
Re: Voltage drop (Searched). Please help.
Check the cables first. They could be old and have to much resistance. I would then turn to the starter. I had a old Caprice that did the same thing every couple weeks. Changed the alt, battery, and cables and the problem still happened. I too had an oil leak right onto the starter. I changed it and never had the problem again. Try to spray some brake cleaner in the starter and let it completely dry before you try starting it. I may just be all the oil in it is causing it to pull down your charging system.
voltage drop jeepnuts311 OEM Tech Discussion 5 January 2nd, 2007 08:53
Voltage drop on 01 XJ mudfun OEM Tech Discussion 7 June 5th, 2006 16:40
Voltage Drop juicexj24 OEM Tech Discussion 3 June 1st, 2006 05:18
voltage drop Andy in Co. OEM Tech Discussion 6 October 26th, 2003 19:32
ac and voltage drop? XJHOX Modified Tech Discussion 3 June 25th, 2003 18:34
