Old February 28th, 2005, 10:06
AndyS AndyS is offline
Water temp sensor placement
I have an aftermarket set of mechanical oil pressure and water temp gauges in my XJ. The water temp sensor is attached to the thermostat housing via a couple of brass adapters. I'm seeing temps close to 240 before the electric fan comes on - is this a bad location for an accurate temp reading? Where would be better, if so? Thanks -
Andy
Old February 28th, 2005, 15:21
Re: Water temp sensor placement
Is everyone using this location for their coolant temp gauges?
Old February 28th, 2005, 17:11
jeepsrock's Avatar
jeepsrock jeepsrock is offline
From what i know the jeep 4.0l engine has two sensors one on the end of the engie near driver firewall which is for the internal guages while the one on the tstat housing is for the compter and fan turn on. As far as the trigger temp for the fan, most ppl say it turns on at 220 but mine never does, it usually comes on when i am close to the red...or should i say when i used to have that happen.
pete
Old February 28th, 2005, 17:45
Does Jeep or any aftermarket companies make lower temp fan switches? If the fan's not coming on 'till the motor gets that hot, I'd rather run a lower temp switch. On the highway, the gauge reads a rock solid 180-185 degrees, no matter what the outside temp. If I have the A/C on in the summer, it'll get up to 210-ish if I'm in stop and go traffic, since the electric fans turn on immediately. However with no A/C, in the summer it gets a bit too hot for my liking.
Old February 28th, 2005, 19:19
Atl XJ's Avatar
Atl XJ Atl XJ is offline
How old is your fan clutch?
Old February 28th, 2005, 19:57
OLD - It's OEM. I know, I know - it's probably not working optimally, but I don't want to go to a super tight replacement clutch. My mileage is crappy enough as it is. Besides - while related to cooling in general, the fan clutch has nothing to do with when the electric fan kicks on...
Old February 28th, 2005, 21:02
Atl XJ's Avatar
Right, and I'm interested in this as well but I'll probably wire in a manual override for it. Mine does the same thing in heavy traffic without the a/c in the summertime, it will get up to 220 or so, but with the a/c its fine. The reason why I mentioned that is becuase if you are only overheating in low speed conditions like that if you replaced the fan clutch it very well could aleviate the problem with no need for other mods.
You could also switch over to dual electrics but be careful that you get an electric fan that is powerful enough. If I remember correctly, 3000 CFMs or higher is neccesary but dont quote me on that. Do a search if you are interested in it, theres a ton of info on the subject.
Old February 28th, 2005, 21:45
MachineMan's Avatar
MachineMan MachineMan is offline
Maybe someone knows of a switch off another vehicle that contacts lower than 220F with the same mount threads. Maybe from a GM or Chrysler...???
water temp gauge... trouble1 Modified Tech Discussion 0 March 1st, 2004 04:39
Water Pump failure questions 2xtreme OEM Tech Discussion 2 December 6th, 2003 06:53
mechanical water temp gauge jeepfreak Modified Tech Discussion 2 June 7th, 2003 19:42
Aftermarket Oil Pressure and Water Temp Gauges MudMedic Modified Tech Discussion 5 May 29th, 2003 12:12
How to remove water temp sensor/ Static-XJ OEM Tech Discussion 0 May 17th, 2003 11:23
