OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
water temp sensor
Was trying to change it as I swapped guages today when the old one broke off. Well it broke pretty much flush with the block, no leak in the coolant system, though. How should I go about extracting the old one. In a really akward position.
Plus the old one has a clip on connector while the new one I bought has a screw on type. Did the parts guy just give me the wrong one? |
#2
The only way that I can think of is to drill a hole in it and use an easy-out to remove it - just like you would extract a broken bolt.
I think that the connection has ridges on it that look like threads, but the connector just pushes on. Good Luck... |
#3
Im a little turned around. What is the sensor on the thermostat housing, and where is the sensor you broke?
#4
The one on the t-stat housing is for the computer. The sensor for the guages is on the top of the block, next to the valve cover, back near the firewall.
#5
I think you have the wrong one, on my 93' the sensors looked almost identical.
Thread Tools | |
Display Modes | |
Water Pump failure questions | 2xtreme | OEM Tech Discussion | 2 | December 6th, 2003 06:53 |
temp sensor resistance (for ecu) | seymouj | OEM Tech Discussion | 1 | September 12th, 2003 12:02 |
Coolant Temp. Sensor | Xtreme XJ | OEM Tech Discussion | 8 | June 30th, 2003 17:16 |
Aftermarket Oil Pressure and Water Temp Gauges | MudMedic | Modified Tech Discussion | 5 | May 29th, 2003 12:12 |
How to remove water temp sensor/ | Static-XJ | OEM Tech Discussion | 0 | May 17th, 2003 11:23 |
