Old February 17th, 2018, 08:04
jmg222 jmg222 is offline
height vs. backspacing vs. stability
I posted on this before, at the risk of being a tad repetitive,
I did a lot of work on my xj last year, 35" tires, clayton long arm, and an 8" clayton lift.
Truck is a bit tippy .. ended up flipping it last year, though in retrospect, a lot of what happened was probably driver error (was driving for years on 33" tires/4" lift, first time out, got cocky...)
I was considering dropping the truck down by 2" to make it a bit more stable. Having literally taken he truck out once with the current set up, I'd rather not get into spending money and lowering it for what I think will be a marginal gain in stability (though I still haven't decided on this)
Just considering other options, I'm also thinking about increasing the backspacing on the wheels, push them out a bit. Any thoughts on this? I know it will put some additional strain on the axles; rear is an f8.8, front is a rebuilt d35 (I know). is this worth trying? looking for people who have actually tried this.
Thanks!
Daily drive: 2018 Jeep Grand Cherokee TrackHawk; stock (for now)
Trail ride: 1988 XJ: Motor/plumbing/electrical: '19 ZZ6 350 sbc, 405HP/405 lb-ft; holly performer EPS, Terminator EFI, headers, novak aluminum radiator; MSD ignition
Drive train: d30 front, F8.8 rear, 4.11 gears, np242 transfer case, rusty under-armor; fully locked with detroit lockers; Chevy 700r4 tranny, 35" MT's
Old February 17th, 2018, 08:23
DutchVDub's Avatar
DutchVDub DutchVDub is offline
Re: height vs. backspacing vs. stability
Not to be a pic whore for my own rigs, but here are my current XJ and the one I had before that (sold it to go JK during a brief moment of insanity). Both on 35's with 4.5" lifts and 15x10 wheels running 3" of back spacing.
Current 98 XJ
My previous 2000
8" of lift is a lot, especially for just 35's. My old 92 XJ was running 6.5" of lift for 37's and was on a slightly wider Waggoneer Dana 40 front axle. I wound up rolling that one, not from the lift height but from a brake line letting go and losing control on an obstacle.
When you're talking about crawling its better to have a lower COG and down travel than it is to have up travel. The lower COG helps with stability and the down travel allows the tires to drop out and maintain traction, plus prevent your belly from getting hung up. Granted with more lift comes more belly clearance, but it doesn't do you any good if your rig goes all teeter totter and falls over every time you sneeze.
Americans can sleep at night because US Soldiers stand ready to fight
Old February 17th, 2018, 08:24
RCP Phx RCP Phx is online now
What's your current rim width and backspacing?
Old February 17th, 2018, 09:20
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
Just get it back down to the 5” range. You don’t need crazy backspacing st that height. A standard is a 8” wide rim and 4”BS
Old February 17th, 2018, 10:08
Originally Posted by 1990JEEPXJ View Post
Just get it back down to the 5 range. You dont need crazy backspacing st that height. A standard is a 8 wide rim and 4BS
I know.. I just got through chopping a roof from another truck, having it welded baack on this one, fixing all sorts of mechanical issues from the roll over. after the roll cage, I don't just don't feel like dropping more $$ into lowering it 2", I don't have a feel for how much it's really going to matter.
I'm thinking of pushing out the wheels a bit, taking it easy on my next trail run, see how that feels.
but if 2" is really going to make a huge difference vs. adding backspacing, may just do that. just need a break from throwing time and $$ at this truck :-)
Old February 17th, 2018, 10:12
DutchVDub's Avatar
2”? You need to drop that thing down 4”.
Just ask any girl how big a difference 2” can make. . Seriously though, with stock width axles there is a huge change in stability between 4.5-5” of lift and 8”. Guys running 1 tons and 40’s are barely running that much lift.
Old February 17th, 2018, 10:51
Originally Posted by DutchVDub View Post
2? You need to drop that thing down 4.
Just ask any girl how big a difference 2 can make. . Seriously though, with stock width axles there is a huge change in stability between 4.5-5 of lift and 8. Guys running 1 tons and 40s are barely running that much lift.
I know.. putting 8" on was a mistake. I'm being lazy. I just don't feel like scrapping all brand new clayton parts that I just put in.
I may try and run with some more backspacing, take it a little easier on the trail, learn the truck. Something will inevitably break this year, when it does I'll drop it down.
Old February 17th, 2018, 16:37
POSJ POSJ is offline
Are you running a sway bar?
Old February 17th, 2018, 18:39
1990JEEPXJ's Avatar
Or you sell/trade lift parts for the correct parts, don’t break anything/roll and everything is hunky dory and cheaper in the end
Old February 17th, 2018, 19:58
nope.
Old February 17th, 2018, 19:59
Or you sell/trade lift parts for the correct parts, dont break anything/roll and everything is hunky dory and cheaper in the end
I know.. or drop down the truck 2-3", and the difference is marginal. just hate ditching everything for an unknown gain.
Old February 17th, 2018, 20:15
stockerwithalocker's Avatar
stockerwithalocker stockerwithalocker is offline
Got Shafted
As an option, you could cut your current coils down and remove a leaf or two.
Old February 18th, 2018, 07:26
whitexj98 whitexj98 is offline
I went up to 6.5 on 35s, didn't like it. Back at 4.5 and its much better. What is your rear setup? Front is just a set of coils, and they really don't cost much.
Old February 18th, 2018, 07:31
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Lower the center of gravity, and trim the fenders as necessary. Buy the necessary parts rather than altering and potentially ruining the parts you have which can be sold.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old February 18th, 2018, 07:50
DutchVDub's Avatar
You are talking about some springs and shocks really. Turn around and sell the ones you have, maybe find some used ones to replace them as an interim. White body cheapo shocks will work just fine as you play around with it. That 2000 XJ I pieced the entire lift together from used parts. I found some used front springs, used leaf springs, used shackles, used adjustable control arms (that one was short arm still), and even the 5150 shocks were used. Between CL and the local classifieds on this forum I found everything I needed to lift it up for pretty cheap.
shackle relocation box lift height? (actual height) muddeprived Modified Tech Discussion 19 December 28th, 2010 00:46
Raptor Line the roof? (UV stability/resilience question) anthrax323 Paint and Bodywork forum 16 October 11th, 2010 20:50
a question about stability xjwest Modified Tech Discussion 13 October 9th, 2008 20:24
Yokohama Geolandar AT+II steering stability rumblebelly Modified Tech Discussion 8 July 12th, 2005 10:07
