Old September 2nd, 2016, 16:56
themauler's Avatar
themauler themauler is offline
Re: My XJ's Big Boy Stage II
Rockdrummer,
My curiosity is wondering what the diff clearance is under the front axle aired up on the Military MTs? You mind pulling a tape measure on that?
Old September 2nd, 2016, 16:59
Rockdrummer93 Rockdrummer93 is offline
Yeah I can as soon as I get them back on.. Which will probably be sometime within them the next week or two
Sent from my iPhone
'01 XJ, Tons and Stickies..
Build Thread
Old September 25th, 2016, 12:27
Starting to get fed up with this PSC system. I took the Jeep out a couple weeks ago and after a few trails the steering got real hard to steer. Would work fine if I brought the rpms up. After probably the 3rd trail I hit I could smell fluid so stopped and popped the hood. Power steering fluid everywhere! Looked like it was the pressure line. Came home and replaced it. Took the Jeep out again Friday got it off the trailer and as I was pulling into our campsite i could smell fluid again and saw smoke coming up from my hood vents. Popped the hood and again fluid everywhere. Had my girlfriend turn the wheel as I watched the pump to see where it was coming from and saw that it was skirting out the front seal of the pump. After talking to a PSC rep I took some pictures and pulled the pump out. Gonna send the pump in sometimes this week and consult with the rep I talked to Friday to figure out why the seal blew out to begin with.
Build Thread
Old October 31st, 2016, 08:09
I think the steering is fixed.. I rerouted some lines and bought a bigger cooler. I probably went a little overkill on the cooler but rather be safe than sorry. Might be going to harlan for thanksgiving break if not then sometime in december with the Clemson Offroad group. Probably won't make both but we'll see,
Build Thread
Old November 28th, 2016, 15:53
So ended up at The Flats for Black Friday. I think I finally got this Jeep working the way I want it to. Need to dial in a couple odds and ends. Steering and all works greats when the Jam nuts don't come loose. Will be getting those set and tacked in now. But other than that all is good!
Build Thread
Old July 4th, 2017, 12:29
So been a good while since I've posted anything on the Jeep. Honestly haven't done much to it since I posted last. I did get a front diff cover for the 60 and got some new rock lights installed.. I did however put the jeep back on the road the other week but so far that's been a failure.. I picked up my old blue labels from the guy I sold them to for $150 with some tread still left and some H2s sometime before that. So it's just like it use to be lol. It's first trip out it was towed back. Jeep has just been randomly shutting off. When I try to start it back up it just turns over, but after it sat for a while it'd start back up for a little while then shut off again. At first I thought it was the CPS so replaced it this morning and took it out. Got to my girlfriend's house to pick her up get back in to leave and it won't start with a new sensor so I don't know what's going on..
Build Thread
Old July 16th, 2017, 18:32
I believe I got the jeep fixed.. put a Mopar CPS in it and it seems to be doing fine.. also installed a header today. Wasn't really planning on it but found one forsale locally that was never installed, so scooped it up. Got an AOP trip coming up in a few weeks. Hopefully gonna claim some redemption from the last time and wheel more then 2 trails haha
Build Thread
Old July 17th, 2017, 08:31
XJAZ XJAZ is offline
I did not see a year for your XJ. I assume you have a 2000-2001 because of the two precats. Whose header did you get?
David
Old July 17th, 2017, 09:22
David
Yeah it's an 01. Not real sure what brand header it is. It was still in sealed plastic when I bought it but otherwise no paper work on it. It does however look like a well built header.
Build Thread
Old July 17th, 2017, 19:11
Evan03 Evan03 is offline
Not sure what you do eith your jeeo butva d44 rear is a tough axle. Do you take it on trails?
Old July 17th, 2017, 19:23
I haven't had a rear d44 for about 3 years now. I do take the jeep on the trails quite frequently. I'm running a pair of Dana 60s now
Build Thread
Old July 31st, 2017, 19:00
So AOP was a fail yet again.. Get up there and the jeep seemed to do alright riding around Friday night not actually hitting any trails. Go out Saturday get in the middle of my first trail and bam dies.. spent like two hours getting it out.. it would start sometimes and run for a little bit then die again and not start back up till it felt like it. Not quite sure what I'm gonna do but need to figure something out..
Build Thread
Old February 21st, 2018, 20:19
Okay so a lot has happened since my last post.. I finally figured out what was wrong with the Jeep.. turns out it was a plug into the interior fuse panel was not clipped in and sliding in and out starting and shutting off.. went on a few trips since fixing that. Harlan, RBD at Busted Knuckle and gulches a few times. Along with picked up some race lines to replace the shitty Chinese beadlocks I kept having problems with. On my last big trip to RBD I steering gave out again. I put a stock pump back on it to finish out the weekend but and since decided to say the hell with it and go full hydro. I was trying to have it together before this weekend for a Hale Mountain trip but PSC dropped the ball on my parts so that wonít be happening.. Iíve got a few plans for the Jeep this year if Iím able to pull them off so stay tuned!
Build Thread
Old March 13th, 2018, 19:56
Steering is all plumbed and working.. still a decent amount of bleeding to do and may have to remount my ram but so far so good. I should have a trip planned within the next week or two but Iíll probably take it to gulches or something to test her out before then. I picked up another slowish project Sunday that will make my wheeling trips a little bit more enjoyable. Found a camper that seems to be just the right size to work with my trailer and give me enough room for the Jeep. It is just a shell so gonna need some work but I hope to have at least one bed and it sealed up soon before my next big trip so that itís usable. Iím probably gonna do a test fit with it and the Jeep in the next day or so before I dive too deep in it just to make sure it does actually fit on my trailer so weíll see..
Build Thread
Old March 14th, 2018, 12:18
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
I'm sure you will, but check your tongue weight with the rig on there. From the pic it looks like the bulk of the weight would be on the ass end.
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Hello everyone! also, Old Stage?... Peach95 Colorado Chapter 9 May 7th, 2015 06:47
Stage 8s not doing their job XJLI Modified Tech Discussion 4 May 27th, 2013 17:59
Old stage again. 4-28 in4aride Colorado Staging Area 52 April 28th, 2012 16:56
xj stage 2 emr1101 Modified Tech Discussion 15 July 20th, 2008 21:39
Jet Stage 2 jcamp1221 For Sale: Private Party Only. XJ ITEMS ONLY 7 April 2nd, 2005 17:11
