Old February 8th, 2021, 16:34
Pnwxj808 Pnwxj808 is offline
Can I use a 1989 rear hatch on a 95 xj?
I’m wondering if anyone on here can tell me how I can get a 1989 Cherokee rear hatch to fit on my 1995 Cherokee. I’ve realized that the wiring harness is different. The 89 has 4 connectors where the 95 has 2 connectors. Is there any way I can get it to work? Thanks for the help!
Old February 8th, 2021, 19:18
Black1990jeep Black1990jeep is offline
Re: Can I use a 1989 rear hatch on a 95 xj?
1..The lift stut attachment points are different. 2.. The latch mechanism is different. and yes 3... the wire feed thrus are different. Modifications will be needed in those areas for sure. And I do not know if it will even fit. I got a 1990, my buddy has a 2001, and we noted the those three differences last week.
Old February 8th, 2021, 20:19
Okay thank you for the help I’ll just get another hatch off of the same year so I don’t run into problems
Old February 9th, 2021, 05:07
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Any 1984 to 1996 tailgate should interchange, check with your local junkyard to confirm. They will look it up in the Hollander Interchange catalog.
Black1999jeep seems to be confused by the 1997-2001 body changes which do not interchange hatches with the 1984-1996.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old February 9th, 2021, 07:19
Anak's Avatar
Anak Anak is offline
Stranger
That difference is going to be about the '96-'97 break in body design.
For the OP, as long as he is staying with pre '97 he has a reasonably good chance the piece will fit.
As Tim said, junkyard interchange manuals are the best source of information in this regard. However, if it is just a matter of wiring that should be fairly simple to overcome. OTOH, if mounting points are different then it is probably more work than it is worth.
Old February 9th, 2021, 09:54
The hatch will fit and line up it’s just the wiring issue Of getting everything to work properly in the hatch like defrost, wiper ect. That’s the biggest issue for me
Old February 9th, 2021, 11:58
Does anyone have a wiring diagram for the body side of the connections so I could wire the 89 hatch to work? That would be a huge help! I appreciate all the help guys!
Old February 9th, 2021, 16:14
Tim_MN's Avatar
Go to www.car-part.com and see if any junkyard nearby has exactly what you need.
You can always go to www.pacificcoastmanuals.com and purchase a genuine Jeep Factory Service Manual which should have all the wire diagrams you need.
Old February 9th, 2021, 16:41
Alright will do thanks for the help!
Old February 9th, 2021, 19:47
four_shot's Avatar
four_shot four_shot is offline
How 'bout it Gonzo
Have you considered swapping the electrical harness from the old hatch to the replacement? I would think the glass connections are the same. Swapping the rear wiper motor over shouldn't be the end of the world either. Or am I missing something?
4shot
"Babs" 97 sport 4.0 aw4
R.I.P."Buster" 86 laredo 2.8 ax5 10/85-9/17
In memory of Dave "Gonzo" Steele 1975-2008
Old February 9th, 2021, 20:30
True I could do that and it would make it easier. Both hatches have the same accessories on it. I just done understand why there is more wires on the 89 than the 95 makes no sense unless like you said the wiper motor is the reason
Old February 9th, 2021, 20:52
Anak's Avatar
Stranger
Power lock?
Old February 9th, 2021, 20:57
No my 95 is all manual lock and I’m pretty sure the 89 i got it off of was also manual lock. The only thing I noticed on the 89 was a wire grounding out to the lock mechanism. I will have to look for more wire but I’m most certain it was only one connection
Old February 9th, 2021, 21:15
Okay so I just checked and there are two wires going to the lock mechanism so I’m going to assume the 89 had power locks
Old February 9th, 2021, 21:58
Anak's Avatar
Stranger
That might not be the only thing in play there. I have no idea how dome lights were wired with regard to the hatch, but that would be another factor to consider.
If there is a solenoid to activate the lock then yes, it would have power locks, but two wires could be just a dome light switch.
WTB 97+ Rear hatch glass or whole hatch two_door_rob MWC For Sale/Wanted Forum 0 January 1st, 2016 22:53
1989 lx hatch, 5.0 built auto 3000$ need gone ct67_72 NAC Classifieds 1 April 6th, 2011 08:04
FS 2 sets of cherokee rear doors and rear hatch SE WI jeepcomj MWC For Sale/Wanted Forum 0 March 15th, 2009 13:56
1999 Rear wiper motor. Hatch Solenoid. Hatch glass (tinted) Odarby For Sale: Private Party Only. XJ ITEMS ONLY 0 June 21st, 2007 16:14
1989 xj rear hatch cj8rckcrlr SEC For Sale / Wanted Forum 0 February 25th, 2007 17:19
