Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
#121
Re: lockers! what ya running and why?
They have drive flanges. I see locking hubs as another likely failure point. Down in Texas where snow is rare. Wouldn't believe it this week.... Mostly trail as well. Yes hydro assist going in Sent from my SM-G975U using Tapatalk |
#122
I thought I did notice the grizzly with tcase disengaged ounce but only tge ounce. I think there's a huge difference driving and being driven in how the grizzly responds.
If tge tcase is unlocked and front is being pushed id say its atleast 95% of thd time unlocked. If tcase is engaged its about 99% locked. It doesn't ratchet pop or make noise its just locked. Sent from my SM-G960U using Tapatalk |
#123
99% locked is perfect.
OX showed up, grizzly here today after a 2 week delay for snow.. time to get these puppies installed! |
#124
I ran an Aussie locker in my 2wd w/8.25 for years. Probably put 200K on it with no problems whatsoever. However, I just picked up a 2001 XJ 4wd with Dana 30 front/Dana 35 rear diffs. Not sure which transfer case I have.
Planning to run 33's with lunchbox lockers front and rear. Off road is mainly sand and occasionally mud. Sound feasible? Anything I need to look out for? |
#125
33s stock gears sand will suck all life out of the rig.
I ran alittle sand with 33s with both 307 and 355 gears.. not even worth attempting unless in 4low. I didnt mind always being in 4low Everyone likes the lunch box lockers. Denverd Looking forward to hearing how you like the grizzly. I've become curious if the characteristics unit to unit are very similar or if they all act alittle differently. When it was brand new I heard a few clicks ratchet sounds. Ounce it had some miles on it it seemed to get silent Sent from my SM-G960U using Tapatalk |
#126
Don’t run lunchbox lockers. Honestly, for the price of a lunchbox locker you could buy a stronger axle than the Dana 35 and swap it in. The mud will eat your lunchbox ‘locker’ and you’ll be $300 poorer with a broke locker. You have a NP231 transfer case. |
#127
With respect to 89Mock, while the NP231 is the most likely (by virtue of it being the "standard" and the NP242 the "optional" case), it's not entirely impossible that boncrshr has a 242.
The NP321 has 4 modes: 2Hi, 4Hi, N and 4Lo. In 4Hi and 4Lo, an orange "Part time" light should illuminate in the instrument cluster. These modes, being part-time, are NOT to be used on-road/high-traction surfaces as with no center diff in the case you risk severe driveline damage. Only use on surfaces where at least one wheel can slip a little. the NP242 has all the modes the 231 does, but adds a "4 Full-time" between 4Hi and N. As with the 231, 4Hi and 4L are part time and illuminate an orange "part time" indicator on the dash. In 4-Fulltime, a green "full-time" light illuminates on the dash instead of the orange "part-time" one. The full-time mode can be used under any conditions as the 242 does contain a differential between the front/rear outputs. Generally the shift bezel on the console and the light(s) on the dash are sufficient to identify your tcase, but if you are missing those (or have reason to believe the vehicle may have been "messed with prior to your ownership), the ultimate answer is to climb under the truck and look at the circular red/white metal tag on the rear of the case itself, which will identify the unit as either a "231J" or a "242J". Rob P.S. I chuckled at your username, boncrshr - liked the reference in it. Do you by chance drive a green jeep with purple trim, and hang out with 5 other similarly-colored XJs? ![]()
1992 Cherokee Laredo: "A wonderful balance of grace and rust" 1984 Dodge Omni 2002 Volkswagen Jetta GLS TDI |
#128
Thanks for the info, sounds like I have the NP231 because the shifter goes 2WD>4Hi>N>4LO. So was 89Mock saying that it would be better to change differentials because the Dana 30/35 were insufficient to handle lockers with 33's? Like I said, having a 4x4 XJ is a whole new experience for me. |
#129
#130
Of course it depends on what ya do with it
#131
I ran my 35 welded
#132
On those scenic trails? Sure. LOL
#133
Ever break it?
#134
Never broke it. Also ran stock k5 blazer axles welded
Yes on the scenic trails. 35 was welded for a few years Sent from my SM-G960U using Tapatalk |
#135
I still have my 2wd XJ with 8.25, and from what I have read here, with any lift at all it is a direct swap. Would switching the D35 out for the 8.25 be a good move?
Thread Tools | |
Display Modes | |
Time for 2ea: Lockers, gears, master kits, lube lockers and Shipping - 1019$ | RWKHausSupply | Vendor's Specials | 5 | November 26th, 2012 08:18 |
Will not stay running (not normal running issue) | bigbadwolf54 | OEM Tech Discussion | 5 | August 26th, 2007 14:07 |
what lockers you guys running up here in northwest? | 93xj-jeeper | NorthWest Chapter | 11 | April 28th, 2005 13:44 |
Calling all guys that are running OX lockers. | hjeepxj | Modified Tech Discussion | 19 | November 11th, 2004 17:19 |
