Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
#31
Re: lockers! what ya running and why?
For me locked means the two axle halves are locked together. Done a good deal of wheeling with many other offroaders with lockers, and when we say "locked" we understand that means the locker is engaged. I guess some folks just don't understand that, and rather fling insults than provide clarification. We have yet to hear from the original poster for clarification. I guess we are all ignorant and full of bunk until then! Ignorance is bliss! ![]() I hope the original poster lets us know, this is an interesting issue. |
#32
Implies a Lock Right style automatic locker, doesn't it ? Saying locker or locked to me, is a locking differential. Spool is spool and welded is welded. denverd1 was not perfectly clear in his post, but assuming one thing or another without clarification from the OP is where your misunderstanding begins.
. ![]() . Quote:
#33
of course a locker can be unlocked. but hey if you think that you are ignorant I suppose, it is all bunk.
#34
Sent from my SM-G950U using Tapatalk |
#35
Auto lockers are designed to unlock and slip when turning on pavement in 2wd. End of that discussion.
Yes I beat the shit out my rig. Stock steering gears are not designed to turn locked 33s. Would a selectable be better? Yes. Was always a temporary solution until I swapped bigger axles. I have no regerts. I'm liking the Detroit rear, e-locker up front concept. Budget? IDK. Is whatever it takes a bad answer? Not a cheap hobby and I want it done right. Sent from my SM-G975U using Tapatalk |
#36
I have auto lockers. Spartan, aussie, lokka.
Not welded, not spools. I do not drive around on pavement with 4wd engaged. I do some dumb shit, but I'm not that dumb. Sent from my SM-G975U using Tapatalk |
#37
ACTUAL QUESTION:
Has anyone run an auto locker (see above) with hydro assist?? Sent from my SM-G975U using Tapatalk |
#38
The larger Dodge Durango steering gear box is a direct fit replacement on the XJ I have done that. I forget the exact years of Dodge that it comes from but an interweb search should find that for you. The Dodge gear box is larger than the XJ box, but bolts in easy anyway. I have had no problem with that gear box and I do have 33x12.5 MT tires and an ARB air locker. I did add a cross brace on the gear box which goes to the passenger side frame. I got the gear box at the wrecker for very little money. I looked for a low mileage wrecked Dodge and checked to be sure the steering fluid is clean before I bought it I use the stock pump. I did add a steering fluid cooler and filter on the return line. That maybe all you need to do, it is a very economical upgrade. What does IDK mean? good luck! |
#39
. ![]() . Quote:
#40
Already bought the ram, fittings and lines.
IDK means I don't know. So whats the difference in a Detroit and a Spartan? Clutch based engagement? Sent from my SM-G975U using Tapatalk |
#41
Full case Detroit, trutrac, Detroit locker? 3 different things?
#42
Go with the full case, it's got to be one of the strongest units out there and a excellent choice!
#43
#44
#45
In my opinion the full case detroit and grizzly sure can't be any weaker than the open carrier with a locker in it.
Im amazed by my grizzly. I wonder if the lunch box lockers work as well just not quite as strong . I ran alot of miles in 4wd today and didn't ounce here the grizzly ratchet. Climbed over some vertical rocks at slow slow crawl that I could do before but had to finagle around and hit the perfect line with alittle umfff because the front didn't want to pull it self up. The welded rear would walk sideways. When I was researching lockers deciding on grizzly or Detroit I didn't really come across any failures in dana 30s heck not even lunch box lockers Sent from my SM-G960U using Tapatalk |
Thread Tools | |
Display Modes | |
Time for 2ea: Lockers, gears, master kits, lube lockers and Shipping - 1019$ | RWKHausSupply | Vendor's Specials | 5 | November 26th, 2012 08:18 |
Will not stay running (not normal running issue) | bigbadwolf54 | OEM Tech Discussion | 5 | August 26th, 2007 14:07 |
what lockers you guys running up here in northwest? | 93xj-jeeper | NorthWest Chapter | 11 | April 28th, 2005 13:44 |
Calling all guys that are running OX lockers. | hjeepxj | Modified Tech Discussion | 19 | November 11th, 2004 17:19 |
