Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
#61
Re: Started my 4.7 Stroker build today.
I have a Chinese aluminum radiator that has been in my rig for about 8 years, but with the Stroker I want to make sure I keep it nice and cool, so before I installed the engine I decided to order a Ron Davis radiator and upgrade, and it just came in today! It is all aluminum and looks really well made. I guess we will see if it was worth it and works well.
#62
Dare I ask how much that cost?
Project "Scope Creep": 1996 4wd 4.0L, AX15 The "Varmint-Mobile": 1997 ZJ Laredo, 4wd, 4.0L, Slushbox |
#63
I got it without the internal heat exchanger for the tranny, so it was a little less expensive than a Griffin radiator, but more expensive than the Mishimoto!
#64
Let us know how it performs with the stroker, particulaly this coming summer.
In fact, you might want to take some good pics now and add it to Cal's radiator comparison thread. I am fairly certain that radiator is not yet represented in that thread. ETA radiator review link: https://www.naxja.org/forum/showthread.php?t=1150722
Project "Scope Creep": 1996 4wd 4.0L, AX15 The "Varmint-Mobile": 1997 ZJ Laredo, 4wd, 4.0L, Slushbox Last edited by Anak; January 20th, 2021 at 21:06. |
#65
Its not. Eric Filar offered me his to compare but it was installed in a car and not worth the effort.
That is one of the best radiators made.
I'm not a complete idiot - there are parts missing. |
#66
'The intake is a ported 2000 XJ intake, so I believe it is the same intake as the 4.0 WJ intake. The intake has had both the throttle body port as well as the intake port opened up. Since the intake is such a pain in the ass to put on, I don't see myself removing it anytime soon and testing other configs/'
Sorry for the confusion from my terms. And thanks for the picture of the intake. The Power Tech is actually a carb hat and probably includes the airbox. Since you mentioned running with out any thing on the TB and losing power. Also, it would be a good comparison to the Thor intake. I could send you the one I have if it helps. Yes, agreed removing the intake manifold is a pain, and I would not ask of that. The reference data I look to that is from Hornbrod on CC. His dyno graph showed a 12 hp gain. I remember one from possibly here and also posted on Mall Crawler from Jordan88 of a 27 hp gain. That though included injectors changed and fuel pressure regulator change. I did a cross calculation from info supplied by Hornbrod as to drive train loss. I calculated that his gain at the flywheel would have been 16 hp. So, I used those to your data and came up with 282 hp. |
#67
Are you talking about the "resonator"?
#68
https://www.allpar.com/threads/the-j...eep-wj.228758/
Here's a link. It has an assembly picture of the V-8 with a 4.7. The blue box on top of the engine. Not particularly what I'd picture as a carb hat, but if I noted it as an Airbox, it might have a different meaning. Also, on the intake manifold, the only noted difference between an XJ and the WJ, is that the XJ has 3 bolts to hold on the throttle cable bracket and the WJ has 2. Then again, my 2000 XJ has the WJ type. |
#69
That's the resonator, do you have any links to actual documentation?
#70
I'm not sure what info as to documentation? As to the 4.0L resonator, I pick one up at the PnP. I kind of view the letter ones lost power due to the exhaust ports. Then made improvements elsewhere to get back the power.
#71
Anything but, "I know a friend who has a friend that has a friend that says this good". Produce documentation or it didn't happen!
#74
I swapped in the AEM 50-1220 E85-Compatible High Flow In-Tank Fuel Pump (340lph) last week to solve the fuel flow problem with my dying fuel pump. I was able to get back to Dyno tuning today. The top pull was 229 HP, which we thought might be borderline knocking , so I ended up going with the 227HP tune. The XJ is a lot
of fun to drive even with 37’s it moves! ![]() Final tune I went with ![]() So with the stroker build I gained about 80 rear wheel horse power. |
Thread Tools | |
Display Modes | |
Started my build today. | Palmentech766 | Midwest Chapter | 5 | January 20th, 2015 17:00 |
Look what I started today | Jump This | SoCal Chapter | 341 | November 12th, 2011 15:09 |
STROKER STARTED!!! Header gets red hot? | NHxj4x4 | Modified Tech Discussion | 9 | July 18th, 2005 19:37 |
Got my stroker started today... | tetsulo | Jeep Street and Performance | 3 | July 17th, 2005 16:32 |
started phase one today!!! | SoNjJeep | Modified Tech Discussion | 5 | June 28th, 2004 09:40 |
