Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
#46
Re: Started my 4.7 Stroker build today.
No, I removed my front inner fenders a number of years ago and got rid of my stock air box.
#48
Thank you for the update.
I will be watching for the updates as I hope to be following this same path in the not-too-distant future. Tuning will be a challenge for me as I doubt there is anyone around here who can do it right. I will need to travel, and a good baseline to get started will be important.
Project "Scope Creep": 1996 4wd 4.0L, AX15 The "Varmint-Mobile": 1997 ZJ Laredo, 4wd, 4.0L, Slushbox |
#49
Glad to hear the thor didn't restrict power! When you get side by side dino sheets that would be something to really geek out on in my book! 😁 You and cal have 2 of the best looking/built xj's I've seen
Sent from my SM-G950U using Tapatalk |
#50
Are there any estimates for power you're hoping for?
on 37s that dyno result is looking pretty cool so far. |
#51
Does it feel like it has more power.
Anak id be glad to tune it if my smarty plugs in. Lol kidding Sent from my SM-G960U using Tapatalk |
#52
Those are still some good numbers, what does your exhaust system consist of?
#53
Ron, I am running the banks headers, but right now everything else is stock. I am planning on going to at least a 2.5" in the future. I talked to Russ last night and he had a customer with basically the same setup as Cal and I and they put out 266/RWHP and 312/TQ on the dyno, so I think I have some room to go up some.
#54
Banks 51306. Header for 00-06 4.0.
I'm not a complete idiot - there are parts missing. |
#56
Ok that makes some sense, I was thinking about his earlier pic of the head and noticed no chem mark around the exhaust ports.
![]() When Russ did mine it was for a Banks Revolver. ![]() |
#57
The flange is the same on both.
The Edlebrock head requires less work on the exhaust ports.
#58
First question is what intake manifold are you using? 99+ Intake or an older one? Ported or not? Thanks for the comparison of the Stock TB to the BBK. I have run a stock, stock bore to 60mm and a BBK 62mm on a stock motor. This is with a 2.5" exhaust and 99+ intake manifold. I notice improvements as to drivability on grade inclines.
I am taking it as your dyno results are from a chassis dyno. Any chance of doing a dyno with the Power Tech intake from a 99-04 WJ? I plan to swap one in to an XJ. It would be a while till a get to that and make some runs. |
#59
![]() Last edited by bajabronco; January 20th, 2021 at 17:22. |
#60
Not to mention Russ does top notch work!
Thread Tools | |
Display Modes | |
Started my build today. | Palmentech766 | Midwest Chapter | 5 | January 20th, 2015 17:00 |
Look what I started today | Jump This | SoCal Chapter | 341 | November 12th, 2011 15:09 |
STROKER STARTED!!! Header gets red hot? | NHxj4x4 | Modified Tech Discussion | 9 | July 18th, 2005 19:37 |
Got my stroker started today... | tetsulo | Jeep Street and Performance | 3 | July 17th, 2005 16:32 |
started phase one today!!! | SoNjJeep | Modified Tech Discussion | 5 | June 28th, 2004 09:40 |
