Old February 9th, 2021, 08:24
az89xj az89xj is offline
Re: D35 -> 8.25 swap parts?
Sorry to dig up an old thread. Have a quick question. Is there a "best" or easiest year for 1989 XJ?
Looking for as close to bolt in as possible.
Thank you
Old February 9th, 2021, 18:30
Evan03 Evan03 is offline
I think they are all bolt in. The yoke is slightly longer on the 8.25 if your running stock driveline and some lift you won't notice the length difference.
As far as I know off hand is if you have ubolts then your golden. Youl also need ubolt plates. However I did slot the holes in my ubolt plates so they'd work
Good luck and have fun with it.
Parts swap at WF 85xjwoody WinterFest 2007 128 February 20th, 2007 16:22
need 231 parts for swap jephs422 Wanted: Private Party Only 2 February 27th, 2005 17:32
231 to 242 swap parts Nihil OEM Tech Discussion 2 February 4th, 2004 09:29
231 to 242 swap parts Nihil Modified Tech Discussion 0 February 1st, 2004 10:04
Swap parts from 99 to 92 xj?? justin d zaharko OEM Tech Discussion 3 August 10th, 2003 14:48
