Old February 16th, 2021, 16:06
jeepingben jeepingben is offline
Re: If I can fit a ZJ fuel tank, anyone can (lots of accesssories)
It could just be that the seal isn't in position. When you do drop the tank, maybe make an access hatch? There are some threads about it.
I had to change my fuel pump a few weeks ago and I was pretty happy to not have to lie in the snow to do it.
Old February 16th, 2021, 16:51
RCP Phx RCP Phx is offline
When I did mine I used a new pump, sealing ring, and lock-nut, but it was still a PITA to do. The FSM also calls for 55ft/lbs on that plastic nut!
Old February 17th, 2021, 09:51
bajabronco bajabronco is offline
My plan of action is to drop the tank again, double check the gasket and sealing ring, bend the float arm up slightly, as well as lower the vent tube a small amount. I am not looking forward to doing this a third time! First time was when I replaced the pump because of the stroker build, second time is last weekend for the tank swap, now to fix the leak. The process of dropping the tank is not horrible, it is just the fumes that get to me, and getting my skid plate back on. Getting the bolts in on the exhaust side with the exhaust, bumper braces and shackle relocation brackets is a pain in the ass.
Old February 17th, 2021, 10:01
Nope, I hate doing things twice or more.
Replacement fuel pump/fuel filter/gas tank? 2000NWXJ OEM Tech Discussion 2 September 26th, 2013 19:57
Warn fuel tank skid with fuel tank jeffsjk NAC Classifieds 1 June 22nd, 2013 09:04
Remove fuel tank to R/R fuel pump m42duster OEM Tech Discussion 9 December 11th, 2010 14:13
Fuel Tank/Fuel Pump Question ddeadserious OEM Tech Discussion 4 June 18th, 2008 20:35
replacing fuel tank o-ring - other methods to solve fuel tank leak rickoregon OEM Tech Discussion 3 February 21st, 2007 14:33
