RSchurig356
- Michigan
Hello,
I have noticed within the last couple of months, my fuel mileage has gotten significantly worse. I used to be able to get around 14-15 MPG in city driving and around 22-24 MPG on the highway. Recently it has gone down to 10-12 MPG in the city and 18-20 on the highway. Nothing has changed mechanically on the Jeep in the past few months, so I am not sure what to check next.
The Jeep is a 2000 4-Door Classic. 4.0L, automatic with 1-year old tires on it. I have always mathematically calculated the mileage, not relying on the computer readout. I have my tires at 36 psi which is 3 psi higher than recommended. What things should I be checking? Is it possible that worn wheel bearings would cause more rolling resistance? Or is it something like a bad O2 sensor that is causing the Jeep to run rich?
Thanks for your help guys.
Ryan
Ryan
