Detroit locker, 33" tires forsale and axle shafts
Bouncy
Flat Rock, MI
Detroit Locker, model number 162C-56A. This item is for Dana 35 axles with 27 spline count and a gear ratio of 3.54 or higher. This item was in perfect working order when pulled. It was meant for my Jeep XJ, but we have since decided to upgrade the whole axle, so we have no use for the locker anymore.
This item is sold AS IS, and will come with its original box.
Price is $300. That's roughly half the cost of a brand new locker.
33x12.5x15 SuperSwamper thornbirds. Set of 5 tires. 4 have 95% tread and 1 has 100% tread. Currently mounted on CJ 5 on 5.5 bolt rims but will dismount if needed. $600 for the set
TJ D35 axle shafts. Stock from a 1997 TJ. $75
PM me if interested. Items located in southeastern michigan.
Also forsale
non-ho head from a 1990 motor. $50
4.0L crank from same $80
Cam shaft from same $25
Pistons and rods from same $50 Pistons are only there for show...they need replacing.
And some more stuff
F250 coil springs...I think they are 3" lift springs...Been told they can be put in an XJ to lift it. Springs look the same diameter. 75 per set...2 sets available.
Brake booster with master cylinder for CJ7 used but works $25
Mopar forged crank for 273, 318, 340. 3.31 stroke. $200
H1 hummer rims and tires 36x12.5x16.5. Rims are 8x6.5 lug pattern and have run flats in them. $250 for set of 4 rims and $300 for 5 rims. tires with rims..PM me for pricing.
