Old March 9th, 2019, 14:15
Weasel's Avatar
Weasel Weasel is offline
anyone else had issue getting waterpump to seal?
I've having a heck of a time getting the inlet hose to the waterpumo to seal. I've had this issue with 2 different brands of water pumps and hoses. I recently upgraded the radiator and switched in a silicone hose I've had for awhile.
And today have a steady drip coming from the inlet of the water pump. Last time I had 2 hose clamps on it to keep it from leaking. I can't get this one to stop leaking either.
It's like the hose clamps don't want to sit square to the neck?
Just add lightness
Old March 9th, 2019, 15:10
ditchdrift ditchdrift is offline
Re: anyone else had issue getting waterpump to seal?
What clamps are you using? You could try a narrow band screw clamp or a constant tension clamp.
Old March 9th, 2019, 15:26
Weasel's Avatar
Ideal work drive style. I'll have to look for a narrow band clamp. I had tried the factory style last time and they didn't seal any better.
Just add lightness
Old March 9th, 2019, 16:05
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
For leaky coolant/heater hoses I always put a thin film of RTV silicone on both the hose and the hose neck. Dry both sides and clean with some solvent. Kinda like a differential, let the RTV skin over slightly, loosely install the hose, and then wait 1/2 hour or so and tighten the hose clamps.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old March 9th, 2019, 17:15
Weasel's Avatar
Hmm had not thought of that, have some Hylomer Blue that is good for this type of thing as it doesn't set up like silicone does. Guess I will be draining the radiator again.
Just add lightness
Old March 9th, 2019, 17:40
The narrow ones are common on European cars if you visit the junkyard.
Old March 9th, 2019, 20:37
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
I had a slow drip in the same place after installing a new lower hose. Solved it by using a constant pressure clamp. That's a bad place for a leak because the hose tends to fit on an angle to the inlet, and not square.
Old March 9th, 2019, 22:17
Weasel's Avatar
I notice that with the hose clamps, they want to pull to the side as well.
Just add lightness
Old March 11th, 2019, 22:12
md21722 md21722 is offline
The inlet is a headache for sure. It's a big hose right behind the power steering support bracket with limited access to the clamp. When using pressure testers on new/dry setup, I find that they will always leak unless I dip my finger in antifreeze and coat all mating surfaces. Have not needed to use RTV or anything like that...
Old March 12th, 2019, 07:07
ehall's Avatar
ehall ehall is offline
I use the worm style clamps on the bottom hose
my '91 beater rebuild
Old March 12th, 2019, 23:29
Weasel's Avatar
Well I got it all to seal up using Hylomer Blue and a constant pressure clamp from the local CAT dealer.
And then the water pump started to leak from the weep hole. And now get to tear it all back apart.
Just add lightness
Old March 13th, 2019, 07:19
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
I just crank the hell out of the regular worm gear style ones, never had an issue.
Did you make sure the hose clamp is entirely on the neck of the waterpump not sitting a little crosswise on the barbed section? I could see that leaving a low clamping pressure area in two places if it was on a little angled. It's not in a very fun spot to work, naturally.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old March 13th, 2019, 09:08
Weasel's Avatar
yeah the wider CAT clamp sealed fine, it's just leaking from another area now. That's the issue I usually have is the clamp ges crooked, guess that a bonus for the spring clamps ands they usually sit flush.
Just add lightness
Old March 15th, 2019, 09:07
jbeintherockies's Avatar
jbeintherockies jbeintherockies is offline
Gates PowerGrip can be a really good fix for something like that. I have used these successfully on another car; no issues, no leaks.
The problem will be getting the heat gun in there to heat the grip clamp in your case.
https://www.gates.com/us/en/fluid-po...lamp/p/p100748
Old March 17th, 2019, 17:39
arto_wa arto_wa is offline
..........................And then the water pump started to leak from the weep hole. And now get to tear it all back apart.
Are you sure it wasn't just a leak from the weep hole all along?
I had that in 89 XJ and first changed the hose four days ago, but ended up changing the water pump yesterday!
Originallyit sure looked like a leaky inlet hose connection when inspecting from under the Jeep, but instead it turned out to be a failed water pump shaft seal.
The weep hole is kind of hidden behind the pulley.
'89 Rear main bearing seal issue Brandon77 OEM Tech Discussion 11 August 5th, 2012 17:37
Is a blown tranny seal a common issue when water crossing? FleXJ96 Modified Tech Discussion 8 July 25th, 2011 10:22
waterpump? thenav Modified Tech Discussion 10 October 11th, 2007 23:13
rear main seal. RTV issue. rag OEM Tech Discussion 19 April 2nd, 2007 23:09
Oil leak issue, seal identification HeavyMetal OEM Tech Discussion 11 February 10th, 2007 10:52
