2000 Fuse Panel ?
Don't have a picture for you, but these fuse numbers and description of what it feeds should help.
1. 25A power outlet
2. 25A cig. lighter
3. 10A Left hdlt high beam
4. 10A Left hdlt low beam
5. 10A Rt hdlt low beam
6. 5A Instr. pnl dimmer
7. 10A Left parking light
8. OPEN
9. 10A Hdlt delay, overhead console cluster
10. OPEN
11. 20A Run/Start Ignition, Daytime Running Lights
12. 10A Rear window defr., Turn Sig./Hazard flasher
13. OPEN
14. 10A Heated mirrors
15. 25A Pwr. door locks
16. 10A Rt. hdlt high beam
17. 15A Radio
18. OPEN
19. 10A Starter relay
20. 10A Trailer Tow Pkge. (in the 2000 it's 15A same function)
21. 15A Horn relay
22. 20A Rear wiper
23. 10A Rt. parking light
24. OPEN
25. 15A ABS, Climate controls, Cooling fan, Brake switch
26. 10A Airbag control module
27. 10A Airbag control module
2000 Jeep Cherokee Fuses
Junction/fuse block (inside kick panel)
Fuse #1 is the large 25A on the top of the left column
Fuse #15 is the large 25A on the top of the right column
Fuse #1 power outlet
Fuse #2 cigar lighter
Fuse #3 left headlamp
Fuse #4 left headlamp
Fuse #5 right headlamp
Fuse #6 Dash lights (switches, controls, gauge cluster)
Fuse #7 license light & the left side turn, parking, marker and tail lamp
Fuse #8 Spare
Fuse #9 compass, sentry key, headlamp delay module, instrument cluster
Fuse #10 transmission range sensor, duty cycle evap/purge solenoid, radiator fan relay, a/c clutch relay, o2 sensor up/downstream relays, back up lamp switch
Fuse #11 transmission control module, power train control module, automatic shutdown relay, fuel pump relay
Fuse #12 instrument cluster, combination flasher
Fuse #13 Spare
Fuse #14 power mirrors, rear defogger & switch
Fuse #15 passenger power lock/window switch
Fuse #16 cargo lamp/switch, courtesy lamps, radio, instrument cluster, under hood lamp, transmission control module
Fuse #17 radio
Fuse #18 power mirror switch, driver power window/lock switch, heated seats
Fuse #19 starter motor relay
Fuse #20 trailer tow harness & trailer turn relays
Fuse #21 horn(s)
Fuse #22 rear wiper switch & motor
Fuse #23 right side marker, turn, parking and tail lights
Fuse #24 Spare
Fuse #25 shift lock solenoid, a/c heater control, abs controller, abs controller relay, blower motor relay, blend door actuator
Fuse #26 airbag control module
Fuse #27 airbag control module
Power distribution center (under the hood)
Looking at the PDC from the front of the vehicle, the bottom right mini fuse is #16, the one above it is #17, the top one in the column is #18.
Fuse #19 is to the left (of #16)
Fuse #16 under hood lamp, transmission control module, radio & interior lights
Fuse #17 O2 downstream relay
fuse #18 coil rail & injectors
Fuse #19 headlamp switch & data connector
Fuse #20 combination flasher
Fuse #22 fuel pump relay
Fuse #23 brake lamp switch
Fuse #25 fog lamp relay
Fuse #26 power amplifier
There's a pic showing the fuse locations for ya.
Is there a fuse for the Front windshield wipers?
I can't find it in any diagrams.
Also-
Is there a relay for the front wipers?
I can't find it in any diagram either.
Thanks for any help=-
Jeff-97XJ
The 2000 FSM shows circuit breaker 30 supplying the wiper switch.
The FSM also shows that the wiper motor's relay is contained within the wiper switch, along with the intermittent wiper circuitry.
Larry
An FSM, handy thing own, isn't it ? Best $ 7.95 I ever spent.
Larry
Thank you so much, I really appreciate your help.
Jeff-97XJ
