So... After breaking off BOTH my rear shock mounts (long story) I started building new ones. I checked around to everyone I could think of, and nobody had a stock height lower shock mount in the rear. Which is important to me as I need up travel, and have my shocks a certain length. A "low profile" mount would eliminate LOTS of up travel for me. So I decided to build a replica of the stocker, but quite a bit stronger
I started off by making a cardboard template, and cutting out four sides. I knew my axle tube was 3" so I just used a 3" hole saw, and cut right down the middle.
The sides are 3/16" and the center sections are 1/4".
Then we got her all welded up!
After that it was time for a trip to the hardware store. We picked up some 4" x 5/8" grade 8 bolts, along with some sleeves, washers, and nuts.
Don't mind the hole being off center, I fudged it up
We then welded the bolt from the backside, and also welded this sleeve to the face of the mount. This gives a nice offset from the frame of the mount so the shock doesn't bind at all. Here one is completely finished and one is missing a single plate (figured out a better way to weld/assemble the second time around.
Then we got to work mounting them up, they're beefy as hell!!
