Old March 4th, 2007, 21:03
reedroalf's Avatar
reedroalf reedroalf is offline
dana 35 disc brake conversion
I heard that you could use the disc brakes off of a '95-'98 grand cherokee to convert your rear brakes to discs. is this true.
Old March 5th, 2007, 07:14
MudDawg's Avatar
MudDawg MudDawg is offline
NAXJA Member #728
Re: dana 35 disc brake conversion
This is one of the most commonly asked questions....there must be a zillion threads on this....
"SEARCH" is your friend....embrace the search.....
Old March 5th, 2007, 08:39
reedroalf's Avatar
i see that there are alot of threads on disk brake conversions, but they are all for the 8.25. i have a 2000 xj with a dana 35 with abs, i would like to be able to retain the abs and parking brake. a parts list would be helpfull.
Old March 5th, 2007, 10:01
bigolexj's Avatar
bigolexj bigolexj is offline
Answer: don't spend a penny on the D35. Upgrade to the explorer 8.8 which includes rear discs already. For the price of a disc brake kit (300-500) or a ZJ swap (150), you can buy the explorer 8.8 complete from most any yard.
Modifications are so minor that you may have $100 in labor into the axle when you're finished and MORE makes a kit for the conversion...
http://www.mountainoffroad.com/catal...20Hardware.htm
Old March 5th, 2007, 16:18
reedroalf's Avatar
I ALREADY HAVE A DETROIT LOCKER AND DIFF GUARDS AND GEARS IN THE DANA THAT WHY I WANA KEEP IT.
Old March 5th, 2007, 17:17
bigolexj's Avatar
No offense intended, but locking, gearing, and "bracing" a D35 is pretty pointless isn't it?
Old March 5th, 2007, 20:09
xcm xcm is offline
your not gonna get much help, with that attitude. and im glad
Old March 5th, 2007, 20:16
IslanderXJ's Avatar
IslanderXJ IslanderXJ is offline
locking & lower gears without upgraded shafts is almost pointless
Diff guard might help with housing flex, but but a truss would help alot.
You should be able to transfer it all to a ZJ Dana-35 that comes with disk brakes and ABS
JoesXJ's Avatar
JoesXJ JoesXJ is offline
Yes a ZJ will work with some work. Now upgrading to a super 35 kit is probably the way to go for you if your gonna wheel with your axle, I think I might do that before I got the brakes done...unless you really need em. You can do the ZJ swap or invest a few more into a teraflex kit ($475 @ Northridge4x4) which will get you all new hardware thats ready to bolt on. Good luck
Old May 21st, 2019, 15:07
Afireinside Afireinside is offline
Sorry just searching, has this been done? I have a d35 with 4.10s and I need to keep the abs,parking brake and would like to add disc's. I need these features because the wife drives it in snow. It's a 95 with 242 so it works very well for her,the abs actually works well too.
Thanks
Old May 21st, 2019, 15:10
Sorry actually I have a spare rear d35 that I plan on doing this to. That way I can build the axle in my garage and swap it. So any input is very welcomed. I will not swap this axle because of the abs.
Old May 21st, 2019, 15:13
TRCM's Avatar
TRCM TRCM is offline
.....and the 'what you have is crap go with something else" is a better attitude ???
Old May 21st, 2019, 15:14
TRCM's Avatar
Thanks
Keeping the ABS will be a lot harder........lemme know when you figure it out
Old May 21st, 2019, 15:22
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
HAHA 12 year old dead thread.....
88 MJ, 4.0, 4wd, 3 pedals, Shortbed.
Mods; ACOS, quick discos, HD tie rod and a bitchin air fresher
04 WJ, 4.7HO
Mods; 3" IRO lift, ADDCO rear sway bar, 4.7HO with bored fastman TB, AFE intake and Superchip tuner, 32s, lunchbox rear 242HD, 3" Kolak exhaust
Old May 21st, 2019, 15:23
TRCM's Avatar
(guess he never figured it out then.....lol)
Dana 35 Dana 44 Disc brake conversion. falcon556 Modified Tech Discussion 1 January 29th, 2007 15:27
Disc Brake Conversion Jeep839 Modified Tech Discussion 36 May 29th, 2005 22:44
Disc Brake Conversion? karter74 Modified Tech Discussion 1 November 19th, 2004 22:48
8.25 disc brake conversion from d44 xj_Patrick Modified Tech Discussion 0 November 3rd, 2004 21:47
Rear disc brake conversion- brake lines bknudtsen Modified Tech Discussion 5 September 2nd, 2004 10:37
