I ****ed up, maybe so bad I can't even pin point wear.
Things I know. She got hot she locked up for a split second at 65 lurched sideways I thought it was clutch transmission. Rodeod her down coasting to a stop
Kinda regrouped still had motor clutch and transmission.
Dana 30 and grizzly then had a tough task minus one inner shaft. Toss it 4wd make the right turn off the freeway welded rear still holding one front squealing rear rumbling. At this point I know I've screwed up. doubtful it let loose for any othere reason than me being at error
Ended up getting a trailer rear was rumbling way to much.
In the garage now recouping seems to much damage to point to anyone thing.
Bad gear (me)set smoked bearing then they loosed up and grenaded letting loose all together of ring gear.
Got so hot the pinion shims are gone.
Anyways getting back on the saddle have a another gear and bearings set will clean shapernel from houseing and see if I can get it right this time.
Gears are from Rons machine. Not sure if he feels bad or just happen stance but yukon gears arrived. Definitely more finished looking than the USA standerd line.
All for now.
All for now.
