Old December 24th, 2017, 09:50
chickenbot chickenbot is offline
Plugs and what do they do?
93 xj np231 ax15
I found some random plugs I just don't know what they are for. They are all located under the dash drivers side.
Old December 24th, 2017, 11:11
lawsoncl lawsoncl is offline
Re: Plugs and what do they do?
Top one looks like the ABS diagnostic connector.
Middle looks like the connection for the ash tray lamp.
Bottom is the connector for the headlight delay module.
Old December 24th, 2017, 12:59
Top- weird because i don't have ABS
Middle- that plug won't reach that far.. Missing the ash tray by 6"
Old December 24th, 2017, 14:48
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
Whatever that middle one is for itís a light of some sort.
Pretty sure Iíve seen a plug like the one in the top picture we donít have ads either.
Old December 24th, 2017, 15:18
Dragonlich1961 Dragonlich1961 is offline
The Orange and Blake is for the ashtray, the light socket has a pig tail on it.
Old December 24th, 2017, 16:02
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Depending on options you will have unused plugs.
My 89 came with speaker plugs to all the doors, under the dash, in the rear deck lid and a plug in for the radio but it was a factory radio delete option. Made it real nice when I went to put one in
Old December 25th, 2017, 06:26
BenWheelin BenWheelin is offline
This is it. There's probably plugs on either end with pink and yellow wires that are waiting for the lower lamp kit to be installed. There's a bracket that screws into the underside of the dash which holds the light socket, I've added it to a few base models so far.
I like being able to illuminate the floorboards.
Old December 25th, 2017, 06:36
I have what you've labeled as the ABS connector without ABS, it would be the only trace of it so far. I have a Bendix 9 system on the back burner that I should look at today and see if it has one as well. I know the 90 has an extensive amount of additional wiring which the one I'm presently building lacks.
I guess it should come as no surprise, especially if there's an ABS slot in the fuse panel.
Also, I'm going to check the late models for the delay module plug because I should have extras around and it's a handy feature.
Thanks.
Old December 26th, 2017, 06:08
Well, the Bendix 9 didn't have the connector on the HVAC cabinet.
The headlight module in the harness from my 86 came out and went right into my 96, neat stuff.
Take a look at my plugs DerMeister OEM Tech Discussion 14 November 14th, 2016 14:59
Spark Plugs 2000 XJ - Only find NGK Nickel plugs no copper. Mtb Jak OEM Tech Discussion 9 April 18th, 2014 17:15
freeze plugs/block plugs. Mitchen OEM Tech Discussion 2 January 23rd, 2011 10:21
plugs POLmagnum OEM Tech Discussion 4 October 1st, 2009 08:22
Help 2 of the six plugs still look new. livewire OEM Tech Discussion 8 October 7th, 2006 20:30
