Lawn Cher'
- Westampton, NJ
Now that our relocation has pretty much fallen into place and I have a new job and can afford to play with the green XJ again, I'm considering making a home brew crawler box similar to the one described on bc4x4.com using 231 low range parts. Now, shortly before I moved, I spent some time & money building up my existing 231 with an AA SYE and Tera 2-low; but I'm thinking that perhaps it will still be the weak link behind an additional 2.72:1 reduction. So my plan is this... use either an early Bronco Dana 20 or Ford NP205 behind the 231 crawler box and save my built 231 for another project. So, anyone have any input as to which would be better in this appliation? I tend to build beefy enough for the way I handle my rig, which doesn't necessarily mean the ultimate in huge heavy duty parts; I tend to upgrade from stock to something adequately strong that isn't overly massive or expensive, which is why I wouldn't consider an Atlas or NV241OR. So, any opinions on Dana 20 versus NP 205? I'm leaning towards the Dana 20 due to its smaller size and weight, both being gear driven in a cast iron case.
