hi guys,
got a nasty knock out of my 91 @ 215.000 km. sound is less loud when in gear but doesn't completely go away. it got louder each day. it wasn't as precise as clockwork - it felt like it was fading out and in from time to time but you could hear it most of the time... it appeared to be the loudest around the bellhousing
my oil pressure is always above the center mark and when revving just slightly under the maximum. oil is standard weight...
the knock getting less loud pointed me towards the rods. so did a few other people hearing the car. i checked the valvetrain nonetheless and the pushrods are straight.
the rod bearings don't have the excessive play they should have. i plastic gauged them and they seem to be borderline all right (1-2 thau' clearance)
the wear pattern on the lower bearing shows only the slightest wear in the center (circlewise, that is the outside is not worn and the center is worn 180 dg.). the top bearings show different wear - the middle of the bearing, on its full width shows signs of wear. the sides (from 0-45 dg. and from 135-180 dg. ) show no sign of wear.
i never looked at rod bearings before and therefore can't tell how they should look.
i checked to of the mains as well to rule out the crank. very even pattern, within specs, no scoring etc...
how should the bearing shells look, do the upper ones usually differ from the lower ones and what else could cause the constant knocking?
i want to get this done, right now the car is sitting in the garage wit the guts open and i need it back as soon as possible.
any help is greatly appreciated,
michael
michael
