Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Tow Rigs and Trailers
Tow Rigs and Trailers Hey, not all of our Jeeps are great on the highway. Post here for tech related to getting your XJ to the trailhead.
Old March 3rd, 2014, 09:57
mcguyver_xj's Avatar
mcguyver_xj mcguyver_xj is offline
wj problems
I am working on a 99 wj 4.7 with the 247tcase which had blown up....my buddy bought a used one and i installed just test drove it and no matter what speed as soon as you let off the gas it starts making a loud rapid clicking noise that slows as the vehicle slows in neutral or drive as soon as you put on gas it goes away....correct 247 fluid was used....sometimes does it minorly on accel around 10-12mph....help?
Old March 3rd, 2014, 10:27
87manche's Avatar
87manche 87manche is offline
Re: wj problems
put a 242 in it, or replace the coupler/chain/sprockets in the 247.
Old March 6th, 2014, 13:52
Re: wj problems
took front driveshaft out now it makes the noise no matter what while driving accelerating and slowing down
Old March 6th, 2014, 17:11
yossarian19's Avatar
yossarian19 yossarian19 is offline
Re: wj problems
I'd put it back
Old March 10th, 2014, 18:46
87manche's Avatar
Re: wj problems
surely put it back.
No 2wd in those cases.
if there's no shaft you're hosing the viscous coupler even more so.
either commit to rebuild, or start planning your 242 swap.
no other way out.
Old March 15th, 2014, 14:59
Re: wj problems
Originally Posted by 87manche View Post
surely put it back.
no other way out.
247 doesnt use a viscous its not like the 249
Old March 16th, 2014, 18:18
87manche's Avatar
Re: wj problems
http://www.jeep4x4center.com/couplin...2329aa-k2.html
http://www.transamericanwholesale.co...RO5012329AA-K1
http://www.ebay.com/itm/Jeep-NP247-2...-/221336550199
https://www.youtube.com/watch?v=r3UzxVONR50
that video shows a gerotor style clutch pack in a package. I'd guess the clutches in yours be boned.
Old March 16th, 2014, 21:37
zachandandy zachandandy is offline
Re: wj problems
Ya it a gerotor with no 2wd, we've driven the wife's a couple miles in low range after the rear shaft spit a ujoint. 231 is going in to fix the lack of 2wd and lack of 4 hi problems. Gerotors don't work well for rock duty. In the varilock axles, may as well be open difs offroad.
Rate This Thread:
starting problems....maybe fuel delivery problems? SeansXJ OEM Tech Discussion 5 November 14th, 2011 22:22
Having problems.... 00DCJeep OEM Tech Discussion 19 May 24th, 2010 14:18
cooling problems or gauge problems? besthaticouldo Modified Tech Discussion 11 August 28th, 2008 15:49
Another xj having problems.. sik4wheeler OEM Tech Discussion 7 January 22nd, 2007 10:43
LED problems littlebluexj Modified Tech Discussion 1 September 22nd, 2005 09:03
