Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > South East Chapter
South East Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
  #16
Old July 4th, 2009, 05:52
jdougn's Avatar
jdougn jdougn is offline
Re: Opinions Needed
Re-gearing is what you'd notice the most and get the biggest end result. Personally, I don't think that long arms and drop brackets make that much difference. I run a Detroit trutrac autolocker in the rear and a Powertrac limited slip in the front. This is not a combination I'd recommend since there is a lot of "push" and "pull" when turning at high speed, like changing lanes on the interestate. It might handle a lot different without the limited slip in the front diff. ymmv
Doug
Old July 5th, 2009, 20:11
High2by's Avatar
High2by High2by is offline
Jack of all trades
Re: Opinions Needed
Go with the drop brackets and if you don't want to spend the money on a selectable, regear to what you want and put a lunchbox in the front. Leave the rear open. (I like the Aussie's in the front)
Originally Posted by Bent View Post
If you run summer oil in the winter two things will happen:
-your engine timing will be off because of the shorter daylight hours.
-Your AC will work fine with summer oil but your heater/defrost requires winter oil.
Old July 5th, 2009, 21:02
16guns 16guns is offline
Re: Opinions Needed
Wow a lot of choices and a lot of different opinions. I am leaning towards selectables and regearing.
Old July 6th, 2009, 14:41
PacificEd's Avatar
PacificEd PacificEd is offline
Re: Opinions Needed
I have close to your same set up. My goals are 4.56 gears, ARB's, and drop brackets. I DD my rig so selectables are a must. I also want to retain the use of my 242 t-case on icy/snowy roads.
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
Old July 6th, 2009, 15:03
Re: Opinions Needed
Yeah ...Arb's and 4.56 soon then HD steering and RC drop brackets...after begging the director of finance ofcourse!
Old July 6th, 2009, 18:48
rockcrusher's Avatar
rockcrusher rockcrusher is offline
Smile Re: Opinions Needed
do you have a pic of your xj with rc 4.5 and 33s. That the sae lift i have and
im trying to decide 32 or 33s did you have to trim wich tires do you have and backspacing on your wheels thanks for your help
Old July 6th, 2009, 18:50
bigalpha's Avatar
bigalpha bigalpha is offline
Oh the huge manatee
Re: Opinions Needed
Punctuation, my friend.
1992 XJ, 4.0, AW4, D30/D35
Old July 7th, 2009, 05:42
Re: Opinions Needed
I have Rusty's Allied steel wheels 15x8's with 3.75 back spacing and 33x12.50 MT/R's. They did rub while turning at the rear portion of the front fenders...so I removed 1" of fender all the way around. Due to the pain of trying to reuse the factory wheel flares I replaced them with a set of Pacer rubber flexible ones from Quadratec (JC Whitney has them too). I can't see spending a ton of cash on Bushwackers right now ( still in the learning how to wheel phase) and with my luck I would rip the Bushwackers off and tear my fenders up. Not bashing Bushwackers...but $42.00 for flexy's is easier to swallow then $400.00 for Bushwackers right now in my opinion. I wrote to JP magazine and my wheel tire combo question was printed in the current (Aug 09) issue under tire fire...but it was edited a lot and I have no rubbing issues on my control arms nor did I have to adjust my steering locks like they suggested. For some reason my PC will not allow me to upload a pic of my rig. Hope this helps out!
Old October 29th, 2011, 12:12
Slonopotam's Avatar
Slonopotam Slonopotam is offline
NAXJA Member #1358
Re: Opinions Needed
Originally Posted by kj139 View Post
As for the lockers...I put in Detroit Trutracs in two friends' YJ's and they are awesome. You can get them for about $400 each, they are un-noticeable on the highway (even in the ice) and they lock up great when wheeling.
Except that truetracks are not lockers. They are torque-sensitive limited slips. One wheel in the air - the other gets no torque. I have them both in front and in the rear.
Old October 30th, 2011, 19:19
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
Re: Opinions Needed
How the heck did you find this? Did you search for "Opinions"?
Rate This Thread:
opinions needed motoman Red River Chapter 29 April 20th, 2009 11:00
opinions needed homebrew SoCal Chapter 9 September 9th, 2006 00:07
opinions needed az4wheeler2002 Modified Tech Discussion 63 November 22nd, 2005 19:44
Opinions Needed Rocketman Modified Tech Discussion 19 January 30th, 2005 06:08
Q's about 8.8, opinions needed lisdexic Modified Tech Discussion 1 January 11th, 2005 18:38
