Old January 19th, 2016, 07:54
Crist Clapper Crist Clapper is offline
Sentry follow-up
Originally Posted by Green Mesa XJ View Post
I've seen on of those clock sensor read outs once in a junk yard almost ten years ago, it was a 86 with a 2.8 and California emissions so it had a computer I though that clock/display ran through.
It had some other cool stuff I grabbed, still have the limited leather/cloth rear seats in my 85 Xj, which is a Waggoner but I always the people Cherokee because it confused with the big Waggoner at the parts counter.
For sure... When stating "Wagoneer"... Folks, even Chrysler folks, think Grand Wagoneer. Now the Chrysler old-timers know of which we speak... Some of the younger folks know them as the "Little" version of the Grand Wagoneer.
I feel compelled to say... Although there are a lot of folks with, and interested in, Grand Wagoneers (Me too as I own one)... The Wagoneer XJ Limited is far more rare.
Old January 19th, 2016, 07:57
OEM Gauges
Hey Since it looks like you have the factory gauges I was wondering if you've seen the problem the printed circuit for the gauges failing and peeling away ?
I ended up upgrading to the newer style cluster because of it. I tried to find a replacement printed circuit but there were none left in the jeep inventory any where. Every used cluster I've ever found around here had a failing printed circuit too.
No problem with mine that I know of.
Old January 19th, 2016, 08:02
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
BUILD: My 1987 "Wagoneer" XJ Limited
I agree. My base or custom (forget what they called it in 85) wagoner is somewhat unique but the limited is a very rare bird IMO. Part of why I snatched all the parts I could from a limited with the same red interior back when I came across it. But my old 85 is never going to be restored to a factory condition, it's had too hard a life long before I saw it and I've been building it up since the late 90's upgrading the axels and other components as needed.
Old January 19th, 2016, 08:11
Wow, maybe it's the heat down south that kills them. Although I bought mine out west originally and it wasn't long before I had to replace the original cluster because it was failing. (Weird thing was when I put a full cluster in the engine already had the right senders, not the ones for the idiots lights the original cluster had. My only guess is somebody swapped the motor sometime)
Early 2000's a old timer at the jeep parts counter tried to help me find the circuit board the close as we came was the first year of the new style. I bought it anyway for under $9 because jeep was clearing them out and it was almost nonexistent. It's sitting in my parts hoard waiting to be needed.
But my luck with the 84-87/88 clusters was very bad.
Old January 23rd, 2016, 15:35
Rear Air Deflector Blade
A good friend who is always on the look-out for me... Found this hard-to-find rear air-deflector (blade). The material is a brushed-aluminum. It is currently at the paint-shop where is will be coated/painted/sanded to a smooth finish to match the OEM paint/finish; Including the mounting-brackets and screw-covers.
Old March 17th, 2016, 16:38
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: BUILD: My 1987 "Wagoneer" XJ Limited
Do you have a source for front side light fixtures, the tall yellow ones the XJ wagoneers? If so please post up here:
http://www.naxja.org/forum/showthrea...#post246312339
Also are the headlights getting hard find? AZ wants $17 for them and only had one of the two in stock.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old March 17th, 2016, 18:11
Let me do some research and I'll be back!
Old March 17th, 2016, 18:46
If purchasing by part #, which I suggest, here they for a Wagoneer:
Old March 17th, 2016, 18:52
Headlamps
NAPA for the headlamps. If I remember... I could not find them on their website... I visited my local NAPA store to cross-reference.
Old March 17th, 2016, 18:56
#10 & 11 Bezels... Search eBay.
Old March 17th, 2016, 19:29
Ecomike's Avatar
NAXJA# 2091
Item number 13 and 14 is what she is looking for. Thanks.
Old March 18th, 2016, 13:57
Sunset Chrysler Dodge & Jeep @ 662-226-5124 may have one each. Reference part numbers 56001528 & 56001529.
Old March 18th, 2016, 14:30
Anak's Avatar
Anak Anak is offline
Stranger
Baby it's cold outside.
Old March 24th, 2016, 11:08
FYI since these is some love for the old Wagoneers here I thought I'd post this: there is a someone in my area with a 1986 XJ Wagoneer for sale on craigs list, yes that means the 2.8 V6.
Thing is he wants almost $8 grand for it. He says check the NADA to justify his pricing.
I got sticker shock just glancing at it.
BTW I don't think the 2.8 is a necessary bad motor, a bit gutless and just not a good as the 4.0, but I never could kill mine it was the "bad" version of the motor with at least 200k I put on it.
Old March 24th, 2016, 11:54
Phil's Avatar
Phil Phil is offline
I have a 1989 Wagoneer Limited. The driver's seat is in pretty rough shape. It was driven for a while apparently with a broken mount, and it has 219k miles anyway.
I know you scored a set of covers, but any guidance on fixing or replacing a badly worn seat?
How about a very worn leather wrapped steering wheel?
It's got the awesome oxblood/cordovan interior.
Spotters lead the way!
My green junk.
1989 XJ Wagoneer. Basically stock.
G & G Offroad and Auto Repair can make you think you can run the Box!
XJ: 1987 Wagoneer Limited Or? Windshield trim? Crist Clapper Wanted: Private Party Only 5 November 13th, 2012 16:41
1987 Wagoneer XJ Limited - Trim color? Crist Clapper OEM Tech Discussion 5 July 15th, 2012 16:11
Parting out: 1987 Wagoneer Limited YELLAHEEP For Sale: Private Party Only. XJ ITEMS ONLY 8 June 25th, 2007 22:55
Parting out 1990 XJ "Wagoneer" Limited XJ&CHZ4ME For Sale: Private Party Only. XJ ITEMS ONLY 14 December 16th, 2006 22:19
1987 XJ Wagoneer 6.5" Lift on 35`s + Extras Fairmonco For Sale: Private Party Only. XJ ITEMS ONLY 12 September 15th, 2006 15:37
